351w engine identification
Old Nov 11, 2005 | 06:24 PM
78 Ranger's Avatar
78 Ranger
where are the casting numbers on a 351w that are used to identify the year
Old Nov 11, 2005 | 07:12 PM
TigerDan's Avatar
TigerDan
Under (or above, depending on your perspective) the starter. You usually have to drop the starter to see it. The casting number gives you the basic info, and the date code located with it tells you the day, month and year the block was cast although it requires a little deciphering.
Mike W
15
Dec 24, 2002 11:31 PM
StockMan
Jan 6, 2002 04:20 PM
carp1
Aug 8, 2001 10:58 PM
frogger01
Mar 15, 2001 06:08 PM
Bruce
May 1, 2000 09:11 PM
