Fine thread or coarse thread bolts ?
Old Nov 11, 2005 | 06:23 PM
54fever's Avatar
54fever
I am going to use Stainless steel bolts to reassemble my truck and was wondering what i should use, fine thread or coarse thread, i can get the coarse thread bolts for free from work, but would have to pay for the fine thread. I guess what i'm asking is does it really matter which one i use, and also should i use teflon lock nuts or lock washers.
thanks, 54 fever
Old Nov 11, 2005 | 06:30 PM
texan2004's Avatar
texan2004
Depends on what you are using them for. If it was fine thread, I'd go back with fine thread. If it was course thread, no problem with course thread. Do you know waht grade stainless you will be using. I'm assuming it is a 300 series which should not be a problem. If it happens to be 410SS bolting, use 304SS nuts to prevent gauling (did I spell that correctly?) of threads.
Old Nov 11, 2005 | 06:49 PM
54fever's Avatar
54fever
i will be using 304 and will be using them on the truck frame to bolt up the running board brackets and all other supports on the frame after i paint it.
54 fever
Old Nov 11, 2005 | 07:10 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
Originally Posted by texan2004
Depends on what you are using them for. If it was fine thread, I'd go back with fine thread. If it was coarse thread, no problem with coarse thread. Do you know what grade stainless you will be using. I'm assuming it is a 300 series which should not be a problem. If it happens to be 410SS bolting, use 304SS nuts to prevent galling (did I spell that correctly?) of threads.
In non-critical applications like brackets, doesn't matter much which you use.
Old Nov 11, 2005 | 07:32 PM
LEckart's Avatar
LEckart
Use some anti-seize on the threads in case you want to remove them later.
Old Nov 11, 2005 | 07:55 PM
54fever's Avatar
54fever
Good advise 56 fun i will definitely be doing that. I remember when i first got the truck and tried removing the fenders, ouch! my hands still hurt!
Old Nov 11, 2005 | 08:43 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Fine threads are generally more vibration resistant, but you'll likely be using lockwashers anyway, right?
Old Nov 11, 2005 | 10:37 PM
huronfarmer's Avatar
huronfarmer
Fine threaded bolts will keep things tighter longer, and when i went to pull all of mine out, such as the running board brackets, none of them were really stuck or rusted at all....but if you use a decent quality coarse thread with lockwashers or possibly even lock-tite depending on the application, you will be just fine.....
Old Nov 11, 2005 | 11:06 PM
Randy Jack's Avatar
Randy Jack
For use on our trucks, either fine or coarse threads will work fine. Fine thread bolts have a higher tensile strength, but we don't really need that in chassis work.
I like to use nylok nuts for most everything. I don't trust lock washers. The nylocks stay there even if they should loosen (or I forget to tighten them). The only time I don't use nyloks is where wrenching them off is really a drag, like up inside the front fender/air dam connections where you can only get 1/4 turn on a ratchet.
Old Nov 12, 2005 | 07:50 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Use the free ones. There's no sense in paying just to get fine threads. Everything in this hobby is expensive enough as it is...
Vern
Old Nov 12, 2005 | 12:21 PM
54fever's Avatar
54fever
Thanks guys, I thought the coarse bolts would work ok, just wanted to double chek with my forum buddies. i like free also, and i can get the teflon lock nuts and anti- seize free to.
Old Nov 12, 2005 | 04:56 PM
AXracer's Avatar
AXracer
Use the lock nuts anywhere you do not plan to loosen/remove them many times. If you reuse nylocs more than a couple times they stop holding. I've been replacing any and all bolts with SS button heads and am using course threads anywhere they are not going into a prethreaded hole. I am using lock washers for the most part because I expect to be removing them several times during this phase. Once I am satisfied they are not coming apart again I'll use nylocs.
Old Nov 12, 2005 | 11:51 PM
laynrubber's Avatar
laynrubber
I like to use fine thread, but for high torque requirements i use course.
I definanatly use fiber loc nuts, lock washers scratch the paint underneath (unless you need a good ground)
Old Nov 13, 2005 | 11:29 AM
fking1's Avatar
fking1
In taking apart my 55, nearly all the bolts were fine thread, especially the body ones. Kept track of the sizes and used fine for fine. In critical applications went to grade 8 too.
Fred
Lex2002
15
May 1, 2025 06:04 AM
Big Jer
Apr 9, 2016 10:39 PM
Diamnd1
Feb 19, 2015 08:35 PM
marcs724
Apr 18, 2013 11:57 PM
