No spark, no idea
Old Nov 11, 2005 | 03:14 PM
Ollie's Truck's Avatar
Ollie's Truck
No spark, no idea
I'm a new member, and a novice under the hood. My truck stalled the other day, it would not re-start. After some basic trouble-shooting, went to the parts store. the following items have been replaced or were with in specs:
Ignition coil
Ignition module
Ignition switch
the plugs, wires, cap and rotor are all new as well. i still have no spark, the starter gets power, the collision switch is reset, and there is gas in the tank.
I'm at a loss guys, would really appreciate any help.
Old Nov 11, 2005 | 04:11 PM
95_4x4_jay's Avatar
95_4x4_jay
Shot in the dark here.
Is the rotor spinning? Just thought maybe the dist gear is buggered. or what about the distributor module?
Old Nov 11, 2005 | 05:12 PM
quicklook2's Avatar
quicklook2
if you spray ether (starting fluid) into throttle body does it run?
Old Nov 11, 2005 | 11:12 PM
Boss429F150's Avatar
Boss429F150
when you crank the truck does it crank normal or fast as if no compression/ timing issue
Old Nov 12, 2005 | 12:06 AM
Bdox's Avatar
Bdox
spark deficit
Pull the wire from the distributor cap and hold it next to a good ground while someone cranks the engine. Have you checked it like that?
If so: Maybe you have a bad resistor wire or possibly a bad fuse link.
Old Nov 12, 2005 | 08:57 AM
Ollie's Truck
Thanks for the replies / advice
The rotor does spin when the engine is cranked (is it supposed to turn slow?)
it sounds like it is cranking normal, just won't start.
I'll try the dist-wire & starter fluid tricks here shortly.
thanks again
Old Nov 12, 2005 | 01:09 PM
Bdox's Avatar
Bdox
thanks again
The distributor should turn at half the crankshaft speed.
Old Nov 13, 2005 | 10:52 AM
Ollie's Truck
Bdox,
Thanks, the distributor is all set, still no spark though. Not sure what else it could be, gets power to the coil, but no power coming out. starting to think the new coil might not be working. not sure what else to do. does anyone have any other suggestions?
Old Nov 13, 2005 | 05:14 PM
Bdox's Avatar
Bdox
OK, here's a primitive coil test: disconnect all the wires from the coil. Hook up a temporary hot wire (A) from the battery to the coil + terminal. Attach another wire (B) to a ground near the coil. Ground the high voltage wire (from the coil.) Hold the ungrounded end of the high voltage wire half inch above where it plugs into the coil. While you are holding it there, take the grounded wire, (B) and tap it on the -terminal of the coil. You should get a spark jump to the high voltage wire if the coil is good.
