Flexplate info???
Old Aug 9, 2011 | 05:21 PM
Brown Falcon's Avatar
Brown Falcon
Flexplate info???
Does a '95 PSD have a different flexplate than a '96 PSD?
Looking at torque converters and it shows the 95 and earlier E4OD with a 4 bolt converter and the 96+ with a 6 bolt converter. So I'm assuming that they have different flexplates... am I right?
Also, where can I get a '96 flexplate if I end up needing one?
Old Aug 9, 2011 | 05:46 PM
superduty4x4's Avatar
superduty4x4
Too bad you didn't buy the flexplate from the goober you bought the trans from...
I honestly had no idea there were any differences.
Old Aug 9, 2011 | 06:05 PM
BuckHammer's Avatar
BuckHammer
What time frame? I can probably hook you up.
Old Aug 9, 2011 | 06:15 PM
427 fordman's Avatar
427 fordman
I'm pretty sure you're right Evan, earlier are 4 bolt, later are 6.
Old Aug 9, 2011 | 06:19 PM
tjbeggs's Avatar
tjbeggs
All OBS PSD flexplates are the same. The IDI's use a 4 bolt TC I believe
Old Aug 9, 2011 | 08:36 PM
arkredneck's Avatar
arkredneck
I know a 96 and 97 flex plate are the same
Old Aug 9, 2011 | 09:24 PM
Brown Falcon
I'll just have to take the inspection plate off and count the studs on mine I guess... unless someone with a 95 chimes in and tells me for sure.
Old Aug 9, 2011 | 09:43 PM
fordpride's Avatar
fordpride
I think the gassers had 4 or 5 studs and the PSD has 6
Old Aug 9, 2011 | 09:54 PM
fordpride's Avatar
fordpride
This is from Rasers X site
I would take it as EARLY meaning 7.3 IDI
The Eagle X4TC is a Racer X USA exclusive converter proudly made in U.S.A. Finally, a vastly improved torque converter for all early E4OD's, 7.3L IDI diesels and all gasoline engines that will improve performance!
X4TC is a 4 stud
X6TC is a 6 stud
Old Aug 10, 2011 | 05:46 AM
tjbeggs's Avatar
tjbeggs
I already did. I've owned 2 95's and have a 97 now.
Old Aug 10, 2011 | 10:45 AM
Brown Falcon
Oops, forgot that you had owned those. So what improvements did you notice with the TC from Racer X? Will that converter and a valve body be sufficient to stand up to my Stage I's for a while?
I just don't want to put that trans in (has 25k on a rebuild) and have it blow up in a few months...
Old Aug 10, 2011 | 11:04 AM
tjbeggs's Avatar
tjbeggs
Its hard to tell since I went from a slipping slush box to a built trans but it seems tighter in its ability to transfer power. Clutch lock is nice but that was also modded with the new pump. All in all its more efficient in transferring power.
Old Aug 10, 2011 | 11:08 AM
Brown Falcon
Who built your trans and what all is in it?
I was planning on the converter and valve body for now, then later on a full rebuild with the Racer X clutch packs and other parts. I just can't afford a rebuild on it right now and my 4x4 swap trans was rebuilt 25k ago.
Old Aug 10, 2011 | 11:21 AM
superduty4x4
Evan have you pulled that TC out to see if you can find a brand name or anything?
Old Aug 10, 2011 | 11:55 AM
427 fordman
Evan, this is just my opinion, probably wrong, but if you do a good convertor and valve body, the trans will hold up just fine as long as you can keep your foot out of it too much. It all depends on your driving style, too much hotrodding and the internals probably won't hold up to long. Drive nice and it will last a long time, especially with only 25k on it. I drive nice as I don't want to spend that big money now either, first of all, don't have it!!
