closed knuckle drive axle
Old Mar 9, 2002 | 06:29 PM
ford_nut's Avatar
ford_nut
i know i asked this before, but no one seemed to provide me with an answer so im gonna try again. i have a 1973 F250 with a closed knuckle frontend. however, this axle has HUGE knuckles----ive seen the standard closed knuckle 44 and the 'ball' shaped ends are signifivcantly SMALLER than the ones i have on my truck. did ford ever put out a closed knuckle frontend with HUGE knuckles??? i have some #'s off a tag and they are kind of hard to read but i think they are
603396-1 4.09 D3TA
thanks again!
Old Mar 9, 2002 | 06:37 PM
alpo23's Avatar
alpo23
It is the HD D-44 , also called the #3500 axle. Bigger u-joint and large external hub, Ford had these as an option for the higher GVW F-250s from '65-'75.
Eric
Old Mar 9, 2002 | 08:31 PM
proeliator's Avatar
proeliator
Yup, I have the same one. Some people knock the closed knuckle design but this is a tough axle that will last as long as you keep it lubed.
Old Mar 10, 2002 | 02:51 PM
jsworkman's Avatar
jsworkman
You have a Standard 4.09 axle that Ford installed in the 1973-1/2 to 1975 ford F-250 HD pickup w/ part time Transfer case The same knuckle was used on the 1974-75 F-250 HD pickup w/ the full time transfer case So yes it is a factory Ford Axle
Old Mar 25, 2002 | 05:37 PM
bigoldblue's Avatar
bigoldblue
Post closed knuckle drive axle
Old Mar 26, 2002 | 07:26 PM
gregdatech's Avatar
gregdatech
Sounds like a dana 60 axle and not a hd dana 44. The knuckles on the 60 were alot bigger, and theres a 60 in the tag code, that I think identifies it as the dana 60. Very desirable axle from what I have read.
Old Mar 26, 2002 | 11:43 PM
jsworkman's Avatar
jsworkman
AXLE Dana 44
Model & Year
1973.5-75
F250 3/4 Ton Heavy Duty Pick-Up
(Part Time Transfer Case)
Axle Type RATIO & (Tooth Combination) Bill of Material
(1)
Trac-Loc 4.09 (45:11) 603396-1,-2
Standard 4:55 (50:11) 603396-3
Information from the
March 1990 Spicer / Dana Front & Rear Axle Kit 1967-1978 Published by Spicer / Dana Corp.
Old Mar 27, 2002 | 05:18 PM
gdavis2265's Avatar
gdavis2265
I have the same HD44 4.09 front axle with HUGE hubs, the center hole in my rims barely clear- never seen hubs this big. Also, I used chevron grease EP-0 (very, very thin) and pumped them full- Won't leak out but still lubes very well.
Glenn
mark a.
Offroad & 4x4
Nov 23, 2008 10:49 AM
billybob_81067
Aug 25, 2005 03:38 PM
mudytoy
Jun 3, 2002 04:09 PM
ford_nut
Jan 28, 2002 09:03 PM
MattL
Nov 6, 2001 06:58 PM
