Sponsored by: Auxito
Transmission problems 98 4.6L
Old Nov 10, 2005 | 07:56 PM
malarky06's Avatar
malarky06
Howdy,
I've been having problems with my '98 4.6L F150 A/T (70k miles). Between 30-45 mph the truck shifts real hard. The truck actually hesitates before shifting, reaches higher rpms, then slams into the next gear. The problem also seems to coincide with the OD light blinking. The OD works fine, the light just blinks after I experience the hard shift. The problem is worse if I use a heavy foot. If I accelerate real slow, and ease up on the gas when I anticipate the shift I can avoid the problem. However, I really have to "baby it." Does anyone have any suggestions?
-Curtis
Old Nov 10, 2005 | 08:53 PM
Monsta's Avatar
Monsta
Sit. Stay.
Check your fluid?
Have you changed your fluid?
OD light blinking means you stored a code in the PCM. You can get it scanned to find out what is wrong...or at least where to start looking.
Old Nov 14, 2005 | 10:44 PM
malarky06's Avatar
malarky06
I've checked my fluid numerous times. It looks fine. I have not had it completely changed yet.
jc82602
1997 - 2003 F150
May 3, 2023 06:09 PM
TAMU05
1997 - 2003 F150
Jan 18, 2015 10:57 AM
rubbersidedown1
Mar 6, 2007 07:42 PM
keepkoolac
May 23, 2004 09:33 AM
