Another Boost Question
Old Nov 10, 2005 | 06:30 PM
jamesj's Avatar
jamesj
I have 00 ex 7.3 engine 4x4. The mods are KN cold air system, Predator @ 60hp setting, 4 inch exhaust turbo back, HX croosover oil prssure hose.
I recently installed the following gauges, pyro, boost, and trans gauges. At 2k rpm cruising speed the pyro reads 600 deg, and the boost pressure never go up over 4 psi. Giong up hill the boost is at 9 psi then down to 4 psi again. First question, is this normal or what can I do to get more boost. All The clamps to the intercooler are tight. The next question is what is the advantage of having a higher boost pressure and how does it affect other components of the 7.3 engine.
Ordered the gauges and pillar from Diesil Manor, and thier instruction and service is awesome. The rest I bought them the sponsors of this site, except the KN ORW gave me a good price.
Hope to hear from you guys, thanks. James
Old Nov 10, 2005 | 06:37 PM
mech2161's Avatar
mech2161
Those numbers are correct for cruise speed and rpm. What boost and pyro numbers do you have at wide open throttle?
Old Nov 10, 2005 | 06:44 PM
jamesj's Avatar
jamesj
The max rpm I put on the engine is about 2500, and the pyro gets to about 900 deg. What rpm is wide open?
James
Old Nov 10, 2005 | 06:55 PM
mech2161's Avatar
mech2161
WOT for me is 4k. Don't watch the tach. When you nail it from a stop what do you see.
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
WOT doesnt necessairly mean hitting the rev limiter. WOT= Wide Open Throttle. usually when you are WOT, the engine is spinning pretty fast. stock PSD's are rev limited at 3500 rpm, but its hard to get there without shifting in an automatic.
Old Nov 10, 2005 | 07:47 PM
Kwikkordead's Avatar
Kwikkordead
Also you won't see much more than 15 psi unless you are towing a trailer or climbing a very steep hill.
orng1
Nov 21, 2014 09:34 PM
DanielT28
Jul 20, 2014 03:26 PM
muddrag1
Oct 31, 2008 01:40 PM
adam red 351
16
Nov 17, 2005 08:40 AM
jamesj
May 16, 2005 09:45 PM
