it is getting cold up here in michigan and it keeps taking longer for the diesel to warm up. 7 to 10 min. looking to add a remote starter. the car audio places around here are having glitches with the ones that they sell. any help with a good brand, or a good place to install one. also i have the xlt with power locks and wanted to have them hooked to the remote as well. thanks for looking.
ps i live in grand rapids mi.
I like the Ultra Start that I have installed.Its pricey though.It pages you if the alarm goes off,when the truck is running and when off,tells you when your doors are lock and unlocked.Theres more,just do a serach.
i checked the ultra start on ebay, and it ranged from $60-100. not bad. it has lot's of features.
2 four button oem style carbon fiber remotes w/ blue led's 4 chanel reciever Passive / active arming starter disable Dual Zone shock sensor Anti-grind output stautus output for bypass modules Dual hyper blue LED's in antannae Valet switch in antannae / No drilling code learn style remote controls 1000' -1500' range antannae w/ built in valet/program button tach/tachless mode, that actually works! starter kill/anti-grind feature remote panic feature/ horn honk wait to start / deisel mode service/ valet mode glow plug input for +/- run time 5 - 45 minutes programmable 2 pulse locks/2/3.5 sec.programmable cold start feature 10 min in 4 hour intervals turbo timer engine idle mode system over ride protection dual car operation / same remote! park light diagnostics up to 4 remote learning capable ignition locking / carjacking feature horn honk output factory arm/rearm outputs extra chnnels for trunk pop/ windows etc... 2nd starter/ignition/accessory output negative out while running output alternating door lock outputs domelight supervision output all potter & brumfield relays on board/60A neg/pos door inputs manual transmission compatable lifetime warranty on all parts!
Hey Strokin, have you installed one of those remotes? From all the things you listed it does I think it would take me forever with a lot of luck to install that. But it sounds cool!
no, i am looking into getting one soon. BlueEyes said he has one and installed it. hopefully not ALOT of wiring and splicing. looked like some unplugging and plugging in between the connections.
I have a Viper alarm/remote starter, 550 model and love it. Bought it locally and had friend install it. Reliable model so far, also has turbo timer built in. Exact model info is in my profile info.
If you live near Grand Rapids GHI of Grand Rapids installs the Ford Gold Remote which is made By Code Alarm. I have it installed in a 2000 Ford CC DRW 4X4 and I love it it works with all of the factory Options. Contact Cliff 1-800-968-9100 address is 3056 Eastern Ave Grand Rapids,Mi
There is alot of wiring,but if you have time and can keep your cool,you can do it.
bought mine and got it installed at circut city... 25 second delay to give the glow plugs plenty of time... cool down feature set up to keep the motor running for 5 mins after i shut it off and i have the remote locks hooked up to the spare button... it is a viper brand... i love it...!
