I just started have a problem with my Ford 1999 7.3 F-350. I was driving down the freeway and the engine just quit. I turned the engine off and then on again and it seem to correct the problem. Then within a mile, it did it again. Again I turned the engine off and on again and it seemed to correct the problem. The "service engine soon" light is now on. I have had the computer modified and the same instrument that installed the new program can also read engine codes. It noted a P1280 & P1670 code. Any help will be appreciated.
Hi and welcome to FTE! Be sure to read this to help you around this site: https://www.ford-trucks.com/forums/s...d.php?t=300691 There are also State, Provincial and International Chapters located near the bottom of the main forum page.
We are glad to have you. Hope you enjoy the site. Check out the various forums. Lots of great info for you.
Looks like you found the correct forum to ask your question. I hope you get it going soon.
