putting body together
Old Nov 8, 2005 | 10:49 PM
fish-albuq's Avatar
fish-albuq
when you guys have put your bodies back together did you guys use the rubber stripping in between parts? i do want to use welting in places but was wondering if the gaskets help alot with noise.
Old Nov 9, 2005 | 09:23 AM
Scott123's Avatar
Scott123
I don't plan on using it this time around. I know it will probably help with the squeeking, but the kind I used last time I did this truck was the stuff with the beaded edge, and I didn't like the way it caught grit and wax. Although this time, the front fenders are going to be fiberglass so I don't think they'll squeek much. On the rear steel fenders I put rolled-on bedliner on the inside of the fenders and continued it around the edge of the bolt flange, so when the fenders were mounted to the bed there's a layer of this rubber coating to insulate from rubbing.
Old Nov 9, 2005 | 10:24 AM
fatfenders56's Avatar
fatfenders56
I use a very thin nylon or teflon washer over the bolts between the panels, it eliminates the squeaks and keeps the paint from chipping
Old Nov 9, 2005 | 10:34 AM
mtflat's Avatar
mtflat
I used a small bead of clear silicone before bolting together. Panels were already painted of course. Fenders got plastic fender welting, but all those front nose pieces got silicone caulk. Four years of daily use on gravel roads and the body is still quiet.
Old Nov 10, 2005 | 08:43 AM
atccracing's Avatar
atccracing
Great, one more of my questions answered! This forum is awsome! You all have so much knowedge to share. I've been wondering myself, what the alternative to the stripping was. I don't want to see anything between the body and fenders.
Old Nov 10, 2005 | 10:11 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Fish,
How much of a gap do you have between your front fenders and the cab?? I recently put my spare front clip on my truck and it seems like there is a huge gap there, 3/8" or more. It seems a bit excessive. I'm going to have tons of work once I start on bodywork....agh
Bobby
Old Nov 10, 2005 | 10:15 AM
fish-albuq's Avatar
fish-albuq
bobby,
I have some but not that bad, i dont think. the gap on the drivers side is about 1/4" and the gap on pass. side is about 1/2". i was hoping to take care of it with some round gasket.
Old Nov 10, 2005 | 10:23 AM
bobbytnm's Avatar
bobbytnm
Fish,
Thanks, It sounds like I will have to do some adjusting. I just set the clip in place to make sure my fabricated radiator support fits. I know I'll have to pull the clip a few more times.
I like fatfenders56 idea of minimizing the gap and using the teflon washers between the cab and the fenders
Bobby
Old Nov 10, 2005 | 11:21 AM
CIAF's Avatar
CIAF
TFE ( teflon) is the best way to go on this one. I have a roll of .018" thick x 3" wide that I use on anything that bolts up. It will not hold water,is inert,has a natural lubricity,and can be cut and trimmed to fit. It is used in leaf springs as as Anti-squeek. If you regulars want some, EM your address and I respond with an address to send the postage stamps. The material will be free. By the way, UHMW, Nylon 6/6, and MDS also work well. UHMW cames in a 1" wide PSA version and I use it on the inner fender to outer fender flanges.
EDIT: The PM/EM blows. If you guys want some mail 5 stamps to:
J.Herrera
1203 Ebony st
Denver,CO 80221
Old Nov 10, 2005 | 11:46 AM
fish-albuq's Avatar
fish-albuq
cabron,
id love to get some of the stuff but hate to dwindle your supply. do you know of a distributor?
Old Nov 10, 2005 | 11:47 AM
bobbytnm's Avatar
bobbytnm
ditto
Bobby
Old Nov 10, 2005 | 11:53 AM
fatfenders56
cabron, id love to get some of the stuff but hate to dwindle your supply. do you know of a distributor?
You can buy it from a spring/suspension shop, it's pretty cheap, some even have it in different colors
Old Nov 10, 2005 | 11:55 AM
atccracing's Avatar
atccracing
Good info, Thanks!
Old Nov 10, 2005 | 12:09 PM
bobbytnm's Avatar
bobbytnm
Go to McMaster-Carr, type in "teflon tape" in the search box
or look in the "raw materials" or "fastening and sealing" section on the home page
seams very reasonably priced
Bobby
Old Nov 10, 2005 | 11:49 PM
mtflat's Avatar
mtflat
Originally Posted by bobbytnm
Fish,
Bobby
Bobby, the stock style foam gasket that's made for this area fills and cushions it nicely. As you tighten the mounting bolts on the cowl and frame the fenders pull into place. 3/8" gap sounds normal here when they're loose.
One source is Sacramento Vintage Ford p. 357 pn 6465-3 $14.50/pr
