Ive been having problems latley with it starting when it is cold when you turn the key it will fire right up and then die then you can crank all day long and it wont start
so far i have replaced the:
cap and rotor
tps
idel air control valve
fuel pressure regulator
with no result but last night i discovered that if i pull the power to the fuel pump it will start right up then plug the power back in and it will stay running
once you get it started it runs like a champ but i think that it is fluding itself out on start up
