Weak Windshield Wipers
Old Nov 8, 2005 | 07:03 PM
hippyman01's Avatar
hippyman01
On my '55 F-100, it seems like the windshield wipers are pretty weak, especially while accelerating. What can I do to correct this problem? Also, is anyone aware of a good site to get a reliable rebuilt carburetor for the 239 Y-Block and a site for older ford truck parts in general? I've found plenty of sites for older truck parts, but it's always nice to be able to price compare... Thanks!!!
Old Nov 8, 2005 | 09:35 PM
texan2004's Avatar
texan2004
I know that electric wiper motors are available if you have a vacuum driven unit now. I'm not as familiar with the modern trucks like yours (post 1952) so I'm not sure if your came with a vacuum wiper motor or not.
Old Nov 8, 2005 | 11:06 PM
texasbob's Avatar
texasbob
Sounds like the stock vacuum wipers. Those things suck. (couldn't resist) Get an electric setup and you will be happier and safer.
Old Nov 9, 2005 | 09:54 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
hippyman,
Welcome to the board!! How about getting some pics of the ol' girl so we can see what you got?
Yeah, the vacuum wipers are a pain in the rear. I think you can pull the vacuum motor assy off, tear it apart, clean it up and get some more life out of it. I read something about it recently but I've slept since then and I can't remember where I read it.
When (and if) you take it apart...
the housing is a half moon shape with a wiper that pivots from the top middle and is moved (sucked) back and forth tripping the vacuum selector to direct the vacuum to the other side of the houseing. I think that you could clean up the inner part of the houseing and relube the felt wiper and get more life out of the unit
I think the article I read used vaseline for a lube but don't quote me on that. Maybe our moderator knows...
Heck, George knows everything
good luck with it
Bobby
Old Nov 9, 2005 | 10:06 AM
Randy Jack's Avatar
Randy Jack
Another idea: A fellow I know with a 50 F1 only uses one wiper (the driver side, of course). He says it is a fine setup and has driven in driving rain up hills with no problems. Apparently, half the load is exactly what the old dear needs.
Rebuilding and lubing it will certainly help also.
Old Nov 9, 2005 | 10:22 AM
fatfenders56's Avatar
fatfenders56
Originally Posted by Randy Jack
Another idea: A fellow I know with a 50 F1 only uses one wiper (the driver side, of course). He says it is a fine setup and has driven in driving rain up hills with no problems. Apparently, half the load is exactly what the old dear needs. Rebuilding and lubing it will certainly help also.
How cool is that? ''If it doesn't work as designed, try doing it half-way''
Old Nov 10, 2005 | 06:28 PM
e william's Avatar
e william
Another solution is to get an electrical vaccume supply, run the wipers on that instead of off the carb or intake. I'm gonna do that with mine, and I hope it comes out alot cheaper than the 150.00 to 175.00 I've seen for the electrical wiper conversion.
Electrical vaccume supplies are also used with cam'ed up motors that have poor vaccume to assist the power brakes.
Ed
Old Nov 11, 2005 | 09:30 AM
1952henry's Avatar
1952henry
Two other possibilities: See if you can get a dual action fuel/vacuum pump, I'm not sure they were available in 1955; you can check in the various catalogs. The other possibility is a vacuum can. These store vacuum and could possibly be hidden out of sight. These vacuum canisters can be found on many Ford products of the 70s. They look like a large soup can. This is providing, as others have suggested, your wiper motor is in good working order. Check the vacuum hose and all connections to make sure you don't have any leaks.
Old Nov 11, 2005 | 12:44 PM
Christopher2's Avatar
Christopher2
Veteran: Navy
Actually the 1948-1952 had a single wiper from the factory the second was an accessory. It could have been if you got 2 windshield wipers you also got the vaccuum fuel pump to go with it.
Old Nov 11, 2005 | 04:55 PM
Broomfieldbum's Avatar
Broomfieldbum
Smile
Years ago, I a friend had a truck that worked fine with rain but didn't work with snow. He took the e clip off the linkage, and at the first site of snow he would disconnect the passenger side. Not real fun for the passengers, but I would reach under the dash every once in a while and manually wipe the passenger side. After 3 years of that he got a different truck and put his good engine in it and found one of the ring seals that slip into the intake manifold, and the block had gotten crooked when we built the engine. He replaced that ring and they worked fine in the new truck. He also replaced all the hoses, but I still say the ring was the leak.
Broomfieldbum
Old Nov 13, 2005 | 11:35 AM
fking1's Avatar
fking1
NAPA is a good source for many 55 F100 parts. I got a rebuilt carb there as well as most all brake parts.
My original electric wipers work when they feel like and are quite slow.
Carpenter, Mid-50's, Obsolete Ford Parts,LMC, National Parts Depot & Hot Rod's (in Ohio) I have used them all!
Fred
Old Nov 13, 2005 | 08:08 PM
bobbytnm's Avatar
bobbytnm
Ed
A good source for electric vacuum pumps is your local wrecking yard. Most of the higher end GM cars as well as the lincolns (I think) had auxillary electric vacuum pumps
Good luck
Bobby
Hellonwheels
Feb 19, 2014 07:18 PM
toofazt
Oct 18, 2012 02:56 PM
69oiler
Apr 28, 2011 08:11 AM
ZukBox II
Oct 11, 2010 03:01 AM
roadtrash43
May 7, 2009 07:23 AM
