Windshield Wiper Squirters
Old Oct 9, 2012 | 07:40 PM
toofazt's Avatar
toofazt
I'm hooking up the stock windshield wiper squirters on my 1966 F100 but I'm not getting power to the electric motor when I pull on the ****. The two speed windshield wiper function works fine. The number cast on the switch is CSTB-17A553-B. Does anyone know the part number? Has anyone pulled the switch apart and fixed it instead of replacing?
Thanks
Old Oct 9, 2012 | 07:50 PM
leonharu's Avatar
leonharu
Do you not have a small button to push above your ignition switch?
Old Oct 9, 2012 | 07:56 PM
toofazt's Avatar
toofazt
No, the wire from the electric motor plugs into the wiper turn **** switch.
Old Oct 9, 2012 | 11:15 PM
toofazt's Avatar
toofazt
I think I found it with my new handy dandy parts catalog: C6TZ-17A553-B
Has anyone had any luck fixing it?
Old Oct 10, 2012 | 08:30 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The two speed windshield wiper function works fine. The number cast on the switch is CS TB-17A553-B.
No such ID number, the 2nd digit in the prefix is a number, not a letter.
Look here: Illustration Section 176.1, Page 3.
Look here: Text Section 176, Page 12 under 17A553
Old Oct 10, 2012 | 01:32 PM
gumshoe's Avatar
gumshoe
the 66 uses a push button for the washers , located in the l/h side of the dash. you might have a chrome plug where the button goes.
Old Oct 10, 2012 | 01:44 PM
Fredbert's Avatar
Fredbert
On my 66 F-250 Custom Cab you pull the wiper switch **** for the washers.
Old Oct 10, 2012 | 02:58 PM
NumberDummy
Originally Posted by gumshoe
Some 1966's use a push button for the washers, located left side of dash, above the ignition switch.
Windshield washer push button (2C-11500) used on all 1965's. 1966's with one speed wipers and on early 1966's (before serial number 760,001) with 2 speed wipers.
1966's from serial number 760,001: The following is the 1966 2 speed wiper switch, that when the **** is pulled out, activates the w/shield washers:
C6TZ-17A553-B .. 2 Speed Wiper Switch-7 terminals (Motorcraft SW-736): Marked with ID number: C6TA-17A553-A or B / Obsolete ~ Dozens available NOS
Applications: 1966 F100/950 & N/NT/T500/1000 from serial number 760,001 / 1966 Econoline from serial number 760,001 / 1967 Econoline / 1967/69 N/NT/T500/1000 & F800/1000.
Old Oct 11, 2012 | 03:53 PM
toofazt's Avatar
toofazt
Thanks for the info, it was a 6, not a S (hard to read the little cast numbers). This switch is the pull for windshield fluid as found on the trucks made later in the year I guess.
Old Oct 12, 2012 | 03:45 PM
camperspecial65's Avatar
camperspecial65
the window washer harness is seperate from the main harness. As I recall this switch has a blade off to the side from the main harness that the washer harness plugs into...the washer harness plugs into the fuse block blade at the top which are always hot...
- cs65
Old Oct 12, 2012 | 07:06 PM
1972RedNeck's Avatar
1972RedNeck
My '66 CC has a billow on the floor.
Old Oct 18, 2012 | 12:18 PM
BarnieTrk's Avatar
BarnieTrk
I suspect it was added later as they were not OEM for '66 Slicks.
I believe the windshield washer floor pump "billow" was optional on the earlier '61-'64 Slicks.
BarnieTrk
Old Oct 18, 2012 | 12:45 PM
1972RedNeck
BarnieTrk
It came from the dealer that way. Maybe they had an old one on the shelf and they stuck it on?
Old Oct 18, 2012 | 12:57 PM
BarnieTrk's Avatar
BarnieTrk
Sounds like a likely scenario...
BarnieTrk
Old Oct 18, 2012 | 02:56 PM
NumberDummy
I believe the windshield washer floor pump bellow was optional on the earlier '61-'64 Slicks.
OEM manually operated and electric foot pump bellow washers were available as dealer installed accessories for all 1953/66 trucks and were factory installed on 500 and larger 1967/90's trucks.
The OEM 1965/66 push button type washers were also available as a dealer installed accessory.
(sigh) OEM: Suggest you invest in 1965 & 1966 accessory brochures. Then you can see all the accessories FoMoCo offered that most of y'all have never seen or heard of.
ZukBox II
Oct 11, 2010 03:01 AM
roadtrash43
May 7, 2009 07:23 AM
AManAndHisTruck
Electrical Systems/Wiring
Dec 3, 2004 11:27 AM
