Sponsored by: Real Truck
Starter doesn't turn off
Old Nov 8, 2005 | 08:51 AM
4wdtruck's Avatar
4wdtruck
The list has been long but this is my current problem. It's a 2004 6.0 4WD with less than 9K miles on it. My new problem is the starter. It keeps turning after the motor has started (up to 2 minutes). I took it to the dealership but I couldn't get it to repeat the same symptom. No word on it yet. The dealership here in SoCal has done great job of fixing the truck in the past. I can't complain the about the dealership's effort. Anybody else have starter problem like this?
Old Nov 8, 2005 | 09:15 AM
elginitis's Avatar
elginitis
maybe the key switch is bad and not releaseing correctly
Old Nov 8, 2005 | 06:23 PM
4wdtruck's Avatar
4wdtruck
When I started the truck, the motor and the starter were running at the same time. I then turn the key back to the off position and the starter still kept running. I can understand the key switch not releasing but not when the switch is turned off by hand. I have done search on this forum. It doesn't sound like a common problem.
Old Nov 8, 2005 | 07:30 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
Starter solenoid could be sticking. I think there are only two ways for starter to keep running - Ign switch failure that keeps 12 v applied to solenoid coil, or solenoid itself stuck. I'd replace solenoid first, just to rule it out. They're not awfully expensive, and easy to change. Good luck.
Old Nov 8, 2005 | 07:33 PM
Gloveman's Avatar
Gloveman
Sounds like a bendix spring to me.
Most likely a bad bendix spring on starter. if not, could be a poorly machined gear, warped flywheel etc, but I would doubt the latter.
My guess, bad spring.
Ask them to replace the stater.
Old Nov 8, 2005 | 07:39 PM
ford390gashog's Avatar
ford390gashog
the starter solinoid is sticking so they should replace the starter.
Old Nov 8, 2005 | 09:03 PM
Astrovan Man's Avatar
Astrovan Man
Many a day goes by when 12 volt feedback through the eletrical system could be polorized. Take a compass and pass it over the starter. if the needle moved 90 degrees, you have polorized current flow through your system.
Old Nov 9, 2005 | 08:07 PM
soupy264's Avatar
soupy264
I had a larger truck that would do that if the voltage got low,ie.didnt start fast and took a few tries. the only way I could get it not to hang in the run position( starter running) was to add a ground to the starter. extra cable to the frame. that ended the problem. may be what astovan man was talking about good luck Phil
Old Nov 9, 2005 | 10:23 PM
99f350sd's Avatar
99f350sd
Wow thats a weird one. I guess you learn something everyday...
Old Nov 9, 2005 | 11:27 PM
4wdtruck's Avatar
4wdtruck
The truck has been at the dealership for 3 days now. No word on it yet but the service rep did tell me there was 2 other trucks a head of me. The truck is more for pleasure so I don't stress. I will let you know how this bottoms out.
Old Nov 10, 2005 | 01:13 AM
texans's Avatar
texans
does your truck have the starter relay on the firewall. I have seen them do the same thing in the past. wires somehow where toching and was allowing power across it to the starter. Causing the starter to do like you where saying. GL
Old Nov 21, 2005 | 11:20 AM
4wdtruck's Avatar
4wdtruck
I picked up the truck on 11/16/05 from the dealer. They could not duplicate the same problem. They did pull the starter and found no damage to the starter or the flex plate. I drove the truck on weekend and I had the starter remain on after I turned the motor off only once. As with some electrical problems, this one is intermittent. This means it won’t be fixed until it happens at the dealership. I thought of having the dealership replace the starter at my expense but haven’t got it through my head why I should pay for something that should be under warranty. I looked on Ford parts Internet sites and wondered the same thing (along with the cost: about $200.00 +or -). Where is the starter solenoid? From the diagrams shown on the sites, it is attached to the starter.
Old Nov 21, 2005 | 09:30 PM
skinner00's Avatar
skinner00
sounds like this could cause a fire or wiring harness to melt. i have seen this many times at my dealership, mostly because people have keys cut and they dont cut well and the customers just dont pay attention
Old Jan 4, 2006 | 11:40 AM
Shad's EX's Avatar
Shad's EX
Just happened on my '01 v10 yesterday, starter would not stop. Replaced with new starter now it seems fine.
Old Jan 4, 2006 | 05:25 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
OK, I'll bite - how could the key cause the starter to keep running if the key turns to the "off" position? I can see it if the key itself sticks in the start position, otherwise ....... what am I missing?
