Sponsored by: Real Truck
Noise When Turning
Old Nov 8, 2005 | 04:48 AM
anmhi's Avatar
anmhi
Cool Noise When Turning
does anyone else have the flat tire noise when turning their 350 King Ranch dually? It really sounds like two flat steering tires when making turns.
Thanks
Old Nov 8, 2005 | 05:22 AM
dmp437's Avatar
dmp437
Model year, milage, two wheel drive or four wheel drive? Does it sound more pronounced from one side of the other?
Old Nov 8, 2005 | 07:36 AM
660grizzman's Avatar
660grizzman
I experienced the same problem last week, twice. Afterwards, I put it in 4 wheel drive and took it right back out and it seemed to quit. I have an '05 Lariat dually. Anyone else have any input?
Old Nov 8, 2005 | 07:51 AM
dmp437's Avatar
dmp437
If it's a four wheel drive one or both of the hubs is "locked" up. My driver's side is doing it right now. I have taken them off and cleaned them but the driver's side is still doing it so my manual hubs (Milemarkers) should be here today.
How many miles? It's a little early for an '05 to have "the problem". Take it into the dealer and get the hub changed. New auto hubs from the dealer are about $300/side BTW (for those of us not under warranty)
Old Nov 8, 2005 | 07:54 AM
660grizzman
My truck has 11,800 miles.
Old Nov 8, 2005 | 10:50 AM
anmhi's Avatar
anmhi
front wheel noise
its an 05 f350 king ranch 4wd dually with 6000 miles and it has been making the noise since brand new
Old Nov 8, 2005 | 10:51 AM
anmhi's Avatar
anmhi
sounds the same from both sides
Old Nov 8, 2005 | 10:54 AM
CmprSpecial's Avatar
CmprSpecial
I hear this noise when the manual hubs are locked in but 4x4 is not engaged. I was told this noise was normal when the hubs are locked in.
Maybe one of the hubs is locked in.
Old Nov 8, 2005 | 11:57 AM
Big Orn's Avatar
Big Orn
Must be ESOF. Is it?
Old Nov 8, 2005 | 12:04 PM
anmhi's Avatar
anmhi
no its manual 4x4 shifter with auto trans
Old Nov 8, 2005 | 12:37 PM
Big Orn's Avatar
Big Orn
I see. Well, I'll have to go with the accidental hub lock theory. Maybe somebody locked the hubs without your knowledge?
Old Nov 8, 2005 | 02:46 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Not that this has anything to do with the poster's problem, but be careful about the "hubs are locked" thing. Even without the hubs locked, if the inner spindle bearing (the needle bearing that the axle rides in) is bad, the axle will turn with the bearing, and you'll have the "floppy axle" noise.
The best way to check things is reach around back of the wheel and try to turn the axle stub by hand. If it moves freely, you're good. If it ratchets or otherwise hangs up and the hub is unlocked, take off the hub and check the axle again, if it's still hanging up, it's the inner needle bearing.
And now, back to our regularly scheduled programming:
Same thing as above, even if the hubs are unlocked, reach around back of the wheel and try to turn the axle stub by hand. It should turn freely, with minimal drag and not ratchet or "grab".
If the axles both turn well, there's something else going on. Check the axles, and report back what you find.
art k.
Old Nov 8, 2005 | 03:15 PM
FortyFords's Avatar
FortyFords
Are you sure its coming from the front of the truck?
Could it be from the rear ?(ls unit grabing) on turns.On dually trucks this gets more prononced because of more tire drag in the rear.
Rich
Old Nov 8, 2005 | 06:22 PM
Redstradic's Avatar
Redstradic
I have an 06 F350 King Ranch SRW and when I lock the wheel all the way in either direction I will get a clunky sound sometimes. This is when I am in 4X2. I was told never to lock the wheel all the way when in 4X4 as it will wear out the parts.
Old Nov 8, 2005 | 06:28 PM
FortyFords's Avatar
FortyFords
you need to crawl under your truck and make sure your axles are free by turning them by hand as Krewat and Mr big have stated above.
We have seen brand new trucks have problems with hubs right from the factory.
Rich
