Aerostar Ford Aerostar
Bad Master Cylinder?
Old Nov 12, 2005 | 09:06 PM
DaveMac2Vans's Avatar
DaveMac2Vans
Update for those interested:
This one is like everything else at this address. . .never simple and always a major event. FYI, this is my 94 XLT extended 3.0. This started out as what I thought was a bad master cylinder. Decided I'd better send it to the shop because of time constraints and other crises. (Wife home and doing well, thanks!) Had pads, rotors, rear shoes, drums done. Still had the same issue, pedal seemed to keep sinking even after a full stop, and at the end of the pedal, the ABS and brake lights came on in the dash. Turning engine off and restarting would always clear the lights, and I could stop the van, but it just wasn't right. Shop guy scratching head at this point, finally called his contact at the factory. Seems to be in either that multi-piped item after the master cylinder or the pulse pump thing on the anti-locks. I am more and more glad I didn't jump into this one. Maybe it will be done on Monday. Will post the final outcome when available.
Thanks!
Dave
Old Nov 12, 2005 | 10:14 PM
73f100shortbed's Avatar
73f100shortbed
It does sound like your master cylinder is going bad. One way to check to be sure is to clamp off the rubber lines to the calipers and the rubber lines to the rear wheel cylinders. You can do this with vise grips, but do not clamp TOO hard or you risk crushing the lines. If your pedal drops with all rubber lines clamped off master cylinder is definitely bad. If it is hard and does not dropthen you need to look elsewhere, broken line ,etc.
Old Nov 13, 2005 | 11:35 AM
DaveMac2Vans
Have checked every inch of line, every connection, every caliper and wheel cyilinder, and all are dry. Replaced master cylinder to no avail. Pretty sure it is in either that multi-piped item after the master cylinder or the pulse pump thing on the anti-locks. They're the only two items left.
Old Nov 13, 2005 | 11:47 AM
xuzme720's Avatar
xuzme720
the multi piped thing is the RABS module...no? believe ken had a solution for that one with a proportioning valve installed in-line. forget the thread it was in though.
Old Nov 13, 2005 | 05:40 PM
ha38349's Avatar
ha38349
could be the RABS valve
Here is a pretty good article on the subject:
http://www.babcox.com/editorial/bf/bf60133.htm
One failure mode is that the RABS valve does not reset completly after ABS kicking in. I recall an article that warned folks not to try and test their rear ABS on older vehicles because it could lead to this type of valve failure.
Old Nov 13, 2005 | 05:43 PM
ha38349's Avatar
ha38349
oops wrong link
I intended to post this link
http://www.asashop.org/autoinc/dec99/techtips.htm
Old Nov 13, 2005 | 09:55 PM
DaveMac2Vans
Thanks for the tips. It may be a few days now. I am stuck with jury duty this week, unless I can get out of it.
Old Nov 14, 2005 | 12:17 AM
copper_90680's Avatar
copper_90680
Just tell the judge: "I don't believe in nobody sueing nobody for no reason" in your best broken English like I did, and you'll be out of it
cchrrice
Mar 5, 2012 09:41 AM
mrplumber
Feb 19, 2012 09:08 PM
|WYG|SS
1978 - 1996 Big Bronco
Jun 13, 2011 10:08 PM
7283-F250
General Automotive Discussion
Jun 12, 2010 09:37 AM
needshave
17
Feb 25, 2009 07:18 AM
