Steering Coupler removal/install???
Old Nov 6, 2005 | 02:42 PM
nsshull's Avatar
nsshull
Question Steering Coupler removal/install???
I will admit, this isnt for a Ford Truck, but a Lincoln Mark V. But the steering assembly's look quite similar, so I'm asking in here. I can not figure out how to take the rag joint assembly off the steering shaft, and I'm quite upset about it because I need a new rag joint, but if I cant get the old assembly and stuff off, I am unable to put the new one on...
Old Nov 6, 2005 | 07:05 PM
bob arrington's Avatar
bob arrington
remove the plastic under the steering collum inside the car, remove the bolts holding the steering collum to the support,open the hood loosen the two bolts and nuts on the rag joint , loosen the splined coupler locking bolt, remove rag joint , reverse to install,bob
badasssapper67
Feb 21, 2017 09:44 PM
FordStolz68
Aug 27, 2016 02:05 AM
vidaliaman
May 13, 2016 11:43 AM
1983F1503004x4
Mar 5, 2013 11:57 AM
VolvoDude
1978 - 1996 Big Bronco
Nov 28, 2010 05:11 PM
