'68 F100 2wd steering
Installed RedHead P.S. Box and a new rag joint, truck still has alot of play in steering wheel. Steering has 1.5" of play before moving rag joint/box. Any adjustments I'm missing? Need shaft?
Draglink, left tie rod and right tie rod end are probably worn out.
Truck has also been converted to a '77 tilt column.
Many of the internal parts are the same: 1971/80 & some 1981/91 misc. Passenger Cars; 1978/91 F100/350, Bronco & Econoline.
Garrett: There's no "joint" associated with the tilt column mechanism. See pic: All the tilt related parts are located above the 7228 shift collar.
Have someone wiggle the steering wheel while your look at the pitman arm attached to the box. If it wiggles in time with the steering wheel, check the connecting link going to the right front wheel. See if there is play at the pitman arm or the wheel. Do the same thing for the left tie rod. Also make sure the shaft going into the box wiggles in time with the steering wheel. If not, double check that the rag joint is good. That's really all there is to check on an F100, the steering system is as basic as it gets.
Elcid
04-20-2016 11:41 PM
djmichael24951
12-06-2015 04:34 PM
IDIDieselJohn
07-14-2009 05:47 PM
tye sheats
12-26-2003 06:23 PM
