Motorcraft Platinum or double platinum?
1990 F-250
Automatic trans.
351
Gas
4X4
Dual tanks
And what kind of wire's should I get?
I still have to take a look under the hood to see what kind of system I have, it is ether a DIS/EDIS system. If I have a Dis system, what kind of cap and rotor should I get? If I have a EDIS system, is there somthing else I should get? Any help would be greatly appreciated.
1990 F-250
Automatic trans.
351
Gas
4X4
Dual tanks
DIS is distributorless ignition system, right? Your '90 has a distributor and one ignition coil. About the only thing platinum plugs are good for is longevity. The regular plugs will be just fine and cost a lot less. I've used NGK's since I've had my truck, but motorcraft/autolite plugs are just fine.
Well I decided that I will use Motorcraft Platinum plugs, Motorcraft cap and rotor and wires. I hope it will work out fine. I still do not know if Motorcraft OEM is anything different then just Motorcraft. I wish somebody could clear that up for me. I also read that someone had a problem with Motorcraft Platinum plugs in a 351, but I am sure that he must of been experiencing other prblems and was just blaming the plugs, considering that alot of people hear seem to like Motorcraft Platinum plugs and I am sure that alot of these people have 351 motors in there trucks.
Thanks to all that helped me out.
They are the same. The bowl is different, but the caps are the same. However, go and look at your distributor, and if there is a gray module with a big flat plug on it, you have the distributor mounted module. If it has a wiring pigtail with a round plug, you have the remote mount module. However, they should both use the same distributor caps.
where are you buying this stuff? The year/make/model should tell them all they need to know.
