FE446 running wierd when cold?
Old Nov 7, 2005 | 09:03 PM
fordraceboy's Avatar
fordraceboy
gotta love those shifts... did 4x13 for a while.. eat, sleep, work is about it!! shift kit and new plugs maybe get another .10 sec?
Old Nov 8, 2005 | 07:39 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Oh yes, 220" wheel base, 3408 Cat, 15 speed Road ranger, twin screw drive axle's,and an Air Ride!! Remember the days well...
Russ
Old Nov 10, 2005 | 11:49 AM
gtex's Avatar
gtex
I cappe doff all teh vacuum outlest to see if that helped. And I didn't notice much. BUt I did notice that he carb mounting nuts were a litle loose, so I tightened them dow. Would a little air under the carb cause it to struggle when cold?
the carb is about to come off anyway for the NOS plate :-) I'll make sure to get it sealed up good then.
Old Nov 10, 2005 | 12:19 PM
76supercab2's Avatar
76supercab2
Dude, is the 446 on the sauce or are you?
First thing I can think of is yes, a vacuum leak under the carb like that could lean out the mixture enough to affect run quality.
Second thing I can think of is that a lean engine on NOx is a dead engine. Better fix that problem first before you make any other mod.
Old Nov 10, 2005 | 01:01 PM
gtex's Avatar
gtex
It runs rich most of the time. The A/F readings on the last dyno run were pretty steady and in the 12s where the Dyno tech said I shold be for about 10:1 compression. So, we're definitely not running lean.
jbwolfe
13
Dec 1, 2012 10:57 PM
twp
1997 - 2003 F150
18
Jul 5, 2012 06:24 AM
Carter78
Feb 27, 2012 07:00 PM
HighboyMac
Nov 10, 2006 11:00 PM
88bii
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 25, 2004 12:07 AM
