Strange Electrical Part identification
Old Nov 4, 2005 | 09:13 PM
rboeding's Avatar
rboeding
I was working under the dash earlier and I found a disconnected electrical part. It has a Motorcraft part number D7AB-10892-A1A number on it. It was completely disconnected from anything and I see no loose wires. Anyone know what it is or what it is for?
Thanks
Old Nov 4, 2005 | 10:26 PM
whalerron's Avatar
whalerron
It would be a HUGE help if you would describe what the part looks like...
Old Nov 4, 2005 | 10:52 PM
stretch351c's Avatar
stretch351c
And where it was located under the dash.
Old Nov 5, 2005 | 12:10 AM
iceman7329's Avatar
iceman7329
Ill look up the part number for you in the morning.
Old Nov 5, 2005 | 06:35 AM
rboeding's Avatar
rboeding
The part is about 3" long and a 1/2" thick and 2" tall. Sorta retangular. It is green and has 4 metal spages on one long end and a squat *** on the other end. The square *** was stuch in a hole behind the gauge cluster on the outside wall of the truck just above and behind the light switch. The part also says HOBBS DIV. SW.
Old Nov 5, 2005 | 10:50 AM
iceman7329's Avatar
iceman7329
The part number is no longer in the Ford parts list on the computer, sorry but I tried.
Old Nov 5, 2005 | 11:16 AM
ford390gashog's Avatar
ford390gashog
give dennis a try. he can decode any of them
Old Nov 5, 2005 | 11:53 AM
Mil1ion's Avatar
Mil1ion
It was originally designed for a 77 Large Ford LTD or LTDII and apparently used on a truck.
Because it fits into the Instrument section of FORD part,I'm thinking Fasten seat belt buzzer switch.
What would the wires run to since they are disconnected ?
Also, Numbers
That is a tag part ID number not the actual Ford Part Number,
People have to realize this.
Old Nov 5, 2005 | 02:05 PM
rboeding's Avatar
rboeding
Well I took it appart and it has an electromagnet in side and a little metal plate that looks like it is supposed to vibrate. Turn Signal Flasher?
Old Nov 5, 2005 | 03:04 PM
LxMan1's Avatar
LxMan1
No, it is the seatbelt buzzer. The turn signal flasher is round.
Glenn54
Dec 8, 2016 05:01 PM
Last chance 53
Dec 2, 2016 07:45 PM
37pro
Jan 7, 2016 05:25 PM
projectdagger
Jul 4, 2012 02:02 PM
nlareau
Sep 7, 2011 04:05 PM
