part number help please..
Old Jul 4, 2012 | 12:13 AM
projectdagger's Avatar
projectdagger
these are from a 1979 f-250 camper specail with a 460 engine and automatic transmission. a few days ago, the ford seemed to have had a small engine fire. which i honestly believe might had been electrical. because part of the wiring harness on the engine is badly damaged.
theses 2 part numbers was on the section of harness.. i honestly do not know what they did.
heres the numbers: d8te-9b right below it reads 982-b2a
Old Jul 4, 2012 | 02:36 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Numbers marked on parts after 1956 are ID engineering or casting numbers, not part numbers.
Engine gauge feed wiring harness, Ford basic ID engineering/part number 14289.
Marked: D8TB-14289-AA = Ford part number: D7TZ-14289-F = 1977/79 F150/350 460.
Marked: D8TB-14289-BB or CA = Ford part number: D8TZ-14289-B = 1978/79 F100/350 351M/400.
D8TE should be D8TB / 9B should be 14289-BB
982 is incorrect for an ID number prefix. Prefix composed of letter, number, two letters.
Besides the engine gauge feed harness under the hood, there is the headlamp wiring harness (basic number 14290), alternator harness (14305).
The main wiring harness (14401) pokes thru the firewall near the master cylinder.
Since your truck is 43 years old, it's possible a previous fire occurred, the fried engine gauge harness was replaced with the one from a 351M/400 or the engine has been swapped.
Old Jul 4, 2012 | 12:41 PM
projectdagger
may i ask.. what are they? i read on another website that it was a bypass for the pcv valve
Old Jul 4, 2012 | 01:38 PM
NumberDummy
I've never heard of, or have seen any such thing as a bypass for the PCV valve.
Your truck had an engine fire, one of the wiring harnesses is burnt, from the numbers you posted, it's the engine gauge feed harness.
Old Jul 4, 2012 | 02:02 PM
projectdagger
thank you for letting me know. just to make sure, it would be best to find a replacement harness before putting the ford back on the road
Chevmn56
Jan 2, 2013 08:30 AM
GIO23
Feb 10, 2010 09:35 AM
68flatbed
28
Nov 26, 2008 11:37 PM
RedTaurus94
Apr 22, 2006 11:53 AM
transam525
Sep 30, 2003 06:58 PM
