Sponsored by: Real Truck
Luk solid flywheel swap
Old Nov 4, 2005 | 11:55 AM
DUKFVR's Avatar
DUKFVR
Does anyone have experience with swapping the dual mass flywheel and clutch to the Luk solid flywheel? Any suggestions? Have hard 160K and starting to make noises, but clutch still looks ok.
Old Nov 5, 2005 | 10:21 AM
CHIEF1302's Avatar
CHIEF1302
LUK Clutch
Put one in my 95 F250 with 7.3 DI and had no problems with it. Towed an 8000 pound travel trailer with it. Just a slight increase in gear noise at low speeds with the solid clutch.
Old Nov 5, 2005 | 02:09 PM
kmans777's Avatar
kmans777
Put a Luk in my 00 about a year and a half ago. No problems, works great. Pedal force is exceptionally light, removing helper spring on pedal will make it more normal if you so desire. Didn't have dual mass flywheel. Your sig says 05, don't belive those have a dual mass flywheel. Not sure when they stopped but I believe it was before 2000. Someone will pipe in with the correct year.
Frozen_Joker
Ford Truck Parts for Sale
Aug 26, 2015 02:59 AM
Charlie Tee
1983 - 2012 Ranger & B-Series
Aug 21, 2015 08:07 AM
dieselsubmariner
Jan 11, 2015 10:39 PM
abowman
Dec 24, 2014 05:53 PM
blue66tang95f150
Nov 12, 2014 08:20 AM
