Thermocoupler install
Old Nov 2, 2005 | 12:58 PM
plowhand's Avatar
plowhand
Playing in the Dirt
I am going to install a pre-turbo pyro on my '95 F250 7.3L. What locations have you used, how hard to install (drill, tap, etc.), any problems with the location (running wires, not getting good readings, in the way of other maintenance work or repairs, etc.). I am leaning towards installing it in the connector from the up pipes to the turbo housing. Has anyone used this location? Is it to far from the maniflods? Any problems with this location? Any and all information will be appreciated.
plowhand
Old Nov 2, 2005 | 02:40 PM
barebackjake's Avatar
barebackjake
ive got mine in that last section of pipe that goes into the turbo. i think its the best location becase its the only place your gonna get both heads. i drilled almost all the way through with a 1/8" bit then drilled all the way through with the drill bit that i needed for 1/4"npt tap. right before i knew i was gonna break through i started the truck to blow the shavings out as it went through. i did use a brass bushing to go into the manifold so just incase i had to get it out later the thermocouple will come out of the brass much better than the cast. i just used pipe thread sealer that is used on steam lines and it dosnt leak at all.
Old Nov 2, 2005 | 04:26 PM
1997F-350's Avatar
1997F-350
i put mine in the manifold right before the up pipe connection. works great good readings and have not had any problems.
Old Nov 2, 2005 | 06:32 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Mine is about 3" back of where 1997F-350 put his. I used a clamp on stuly probe in the up-pipe. Super easy. No taps, no thread sealant, just a 1/8" hole a washer and a clamp.
Might have been a 1/4" hole....it was almost five years ago.
fordnc
Mar 17, 2009 06:24 PM
RÖENTGEEP
Feb 10, 2009 02:21 PM
plowhand
Jan 20, 2008 09:45 AM
yukonsly
60
Apr 19, 2007 03:26 PM
plowhand
Nov 12, 2005 04:47 PM
