switching from points to electronic ignition
Old Apr 15, 2002 | 06:05 PM
camaroman76's Avatar
camaroman76
I am taking the cab off of a 76 f250 4x4 because it is shot and am putting on a cab from a 73 f100 2wd. The problem is that the 73 cab is not wired for the electronic ignition box that is on the fender. How do I wire this so that I can use electronic ignition on this cab? Is it hard or is as easy as a power lead and a ground to make it work? Any help would be greatful. Shannon.
Old Apr 15, 2002 | 10:08 PM
dvlinnell's Avatar
dvlinnell
Its pretty easy to do, you should be able to use all your wiring from your 76. If you have a blue tab module, which I hope you do, youll notice there are only two wires going into it from the cab, one wire is for run, the other is for start. When you are in the start position on your ignition switch, the module is sending 12 volts to the ditributer, when its in the run (ignition turned on) the module is sending less voltage. You can use just one wire if thats all you have to work with, but you need to make sure its the lower voltage side of the module. I cant remember which wire it is though, but you should be able to figure it out.
Old Apr 17, 2002 | 06:30 AM
lshort's Avatar
lshort
you will already have the resistor wire. Just follow the diagram.
Larry
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=3864&.jpg
Old Apr 17, 2002 | 07:30 AM
itlkick's Avatar
itlkick
tofargone
Mar 31, 2014 09:58 PM
'nilla60
Nov 5, 2009 05:48 PM
fairelectric
Apr 28, 2004 03:43 PM
shannonS
May 26, 2003 05:01 AM
camaroman76
Apr 20, 2002 01:39 AM
