General Automotive Discussion
Cherokee wobble
Old Oct 31, 2005 | 01:01 PM
Cudighi's Avatar
Cudighi
Cherokee wobble
This is a 99 Jeep Cherokee. Steering wheel wobbles bad at 50-60 mph. Rotated and balanced tires. Changed steering stabilizer. Had it on jacks last night and all seems tight. Even had another opinion while it was up. Nothing obvious. One guy said he's seen tire ply separation throw them off. Couldn't see the plies separating. Changing out tires seems to be a big cost for an unknown fix. Anyone else run into this on a Jeep?
Old Nov 2, 2005 | 04:36 PM
The Tree's Avatar
The Tree
Have you checked the track bar bushings, that happened to my 95. Also make sure the bushings are good on the upper and lower control arms.
Old Nov 7, 2005 | 06:15 PM
Bdox's Avatar
Bdox
First, swap the front tires for the rears and try that. If it's still the same, and your front end is all good and tight, maybe your front shock are shot.
Let us know what works.........
Old Nov 8, 2005 | 01:00 PM
99-B-4000's Avatar
99-B-4000
I had this happen on my 98 cherokee I was told change the steering stabilizer by friend(mechanic). I also changed the sway bar end links because the bushings were crushed. I don't know what worked but the death wobble is no more.
Old Nov 8, 2005 | 01:52 PM
goodie350's Avatar
goodie350
My sister had the same problem on her 98. I put on new shocks and a steering stabalizer. It was alot better than before but would still occasionaly do the death wobble. She needed new brakes so replaced with new rotors at the same time. Wobble went away till the day it was wrecked a year later.
Old Nov 8, 2005 | 05:33 PM
AlfredB1979's Avatar
AlfredB1979
"Death wobble" already on a Cherokee?
I remember reading on that, to some extent, on the Jeep forums at 4x4wire.com. Maybe that's not it, though.
Good luck.
Old Jan 12, 2006 | 10:18 AM
Cudighi's Avatar
Cudighi
Just following up on a thread I started a few months ago. Come to find out, it was the tires. Got them changed today and it's good to go. Thanks for the replies everyone.
Old Jan 12, 2006 | 03:58 PM
76 F-150 390FE's Avatar
76 F-150 390FE
our 96 is doing it too starts at bout 55 clear through 65-70 wasn't that bad then it got towed becuase of forgetting to put a parking permit up and after that it get really bad.
Old Jan 12, 2006 | 06:59 PM
Cudighi's Avatar
Cudighi
I had the drive shafts checked before I went with the tires. I bummed rear tires off of a friend and threw them on.
Old Jan 13, 2006 | 04:32 PM
99-B-4000's Avatar
99-B-4000
Glad to see you solved the problem. When that wobble happens at that speed it's alittle scary.
Old Jan 13, 2006 | 05:00 PM
GlennFordx4's Avatar
GlennFordx4
You know I have been wanting a cherokee and talked with a lot of people that own them and always hear about front end problems even low mile ones so now I am not so sure.
Old Jan 13, 2006 | 06:15 PM
76 F-150 390FE
if you get one get it with the 4.0 high out put, they aint liein when they say high out put that thing has some power. it aint that bad, i like it because of the power it puts out and the handeling is awsome i live on a mountain and nothin gets around them windy roads like it
Old Jan 13, 2006 | 06:27 PM
dkstuck's Avatar
dkstuck
When I saw this title, Cherokee wobble, I kept on thinking of, "Indian Fire Water"
Old Jan 13, 2006 | 08:43 PM
Bdox's Avatar
Bdox
I had a 92 Cherokee and the only wobble I experienced with it was because of tires. Put 100k mi on it and never had a front end problem. It may be that they are sensitive to tires that are out of round or out of balance. Other than that they are fine. I liked mine a lot, because of the size, configuration and manuverability. If I could find an older one without any rust I would buy it. The only reason I don't have it now is that my wife gave it to our son. (That was strike two.)
BillyBob69
Oct 9, 2012 06:18 AM
SuperKram
Aug 6, 2008 03:30 PM
Rikster-7700
1997 - 2003 F150
Apr 5, 2007 05:28 PM
milocj
2004 - 2008 F150
Jun 11, 2006 08:45 PM
8-lug
Offroad & 4x4
16
Feb 4, 2005 02:37 PM
