Air Pump
Old Oct 31, 2005 | 10:16 AM
ScottyB's Avatar
ScottyB
Air Pump
Saturday I installed new plugs/wires on my truck, along with a new gasket at the carb base. Everything went well. I disassembled as little as possible in the process. Now the air pump has seized up. Is there any other explanation other than the bearrings just decided to go now. Coincidence????? Or could it be something I did. How much is a reman pump?
'86 F250 4x4 351w
Old Oct 31, 2005 | 12:15 PM
loudfords's Avatar
loudfords
How long had it been sitting? It's typical for them to seize up after sitting, what with a steel vane in an aluminum housing and all....
You can usually grab used ones at wreckers fairly cheap.
Old Oct 31, 2005 | 12:44 PM
ScottyB's Avatar
ScottyB
It wasn't. It's my weekend truck, so it doesn't get much use, but it sits only for a few days or a week at a time.
Old Oct 31, 2005 | 11:27 PM
Zane M's Avatar
Zane M
I doubt it was anything you did, it probably was just coincidence( it is a 20+ year old truck after all). I don't know about the price on a reman, as inspection stations here are pretty lenient on the visual portion of the smog test, as long as it will pass the sniffer-I have left mine off.
Old Nov 1, 2005 | 09:07 AM
Sycostang67's Avatar
Sycostang67
I think they have those stupid lifetime sealed bearing that you can't lubricate. My truck has 2 air pumps, and 1 of them was seized when I got it. A new pump costs about $300, while the reman was $30-$50 I believe. I leave the belt off of the pumps though, only putting it on for the smog test.
Old Nov 1, 2005 | 12:25 PM
ScottyB's Avatar
ScottyB
I'm not concerned about any smog tests.
So, If I leave the belt off the pump will I need to make any adjustments or should the motor run the same with our without it?
Thanks for your help so far.
Old Nov 2, 2005 | 06:09 PM
Sycostang67
My truck runs just fine without it.
Old Nov 2, 2005 | 06:18 PM
ford390gashog's Avatar
ford390gashog
the truck will run fine without it but if you have a cat it will ruin the cat. the air pump injects air into the system to assist the cat burn leftover fuel.
Old Nov 2, 2005 | 06:36 PM
Sycostang67
Good point, I don't need cats, so I didn't even think about that.
Old Nov 3, 2005 | 06:35 AM
ScottyB's Avatar
ScottyB
Thanks guys,
I will disable the pump for now and try to get a rebuild or used one on soon.
Later
Tim Hodgson
Feb 12, 2015 09:56 AM
saezjose
Bronco II
May 3, 2008 02:20 AM
MikeWire
May 15, 2007 03:55 PM
holly
Bronco II
Jul 13, 2000 02:59 PM
