Sponsored by: Kumho
intermittent pull to right
Old Oct 30, 2005 | 07:46 PM
stretch5881's Avatar
stretch5881
Question intermittent pull to right
Tuff problem for me. I can drive down the road and it has a sudden pull to the right for 2 to 5 seconds. Steering can be ok for a while, then it will do it again. Truck is an 85 F150 4X4. New steering box, calipers, tie rods, steering link, ball joints and lockouts. Front end aligned and checked for any movement or worn bushings. Problem remains.
Old Nov 1, 2005 | 10:39 PM
zemus420's Avatar
zemus420
Sounds like your right break caliper is locking up. Maybe a bad Master Cylinder. If the calipers are new I would try looking into seeing if your MC was bad.
Old Nov 2, 2005 | 04:40 PM
stretch5881
Thanks for the reply. If it were the brakes, I would think it would be more steady. It pulls for a short time and then it's fine for a while, then it may or may not pull again. All without touching the brakes. I did although lock the hubs in today and found it drove as nice as could be. I did have a bad lockout on the right side and replaced them with new, but unlocked, still an intermittent pull.
Old Nov 2, 2005 | 09:09 PM
gmoneyword's Avatar
gmoneyword
Check the wheel bearings
Old Nov 8, 2005 | 05:16 PM
stretch5881
Wheel bearings were the problem. Thanks.
insurr3ction
Dec 1, 2018 12:53 PM
Happyreefer
22
Sep 19, 2016 07:49 PM
superduty2001
Jul 24, 2016 07:45 PM
blackford4x4
Mar 11, 2015 08:39 PM
redbell39
Aug 22, 2009 01:37 PM
