Removing blower motor
Old Oct 30, 2005 | 04:36 PM
staysbroken's Avatar
staysbroken
The Haynes manual says it is necessary to remove the heater core (and drain coolant of course) to get to the blower motor. Has anyone been able to remove theirs without removing the heater core?
My blower motor makes a horrible noise when it's on - I'm guessing it's bearings. I'm just hoping fixing it won't become that big of a project...
Old Oct 30, 2005 | 04:52 PM
T.R.Bauer's Avatar
T.R.Bauer
Blower motor
Does it have A/C? If so this can be a major undertaking. You have to get the ac crap out the way too. It is also expensive when you recharge it....if it has ac go get it done so the refridgerant doesn't make our hole in the ozone layer any bigger.
T.R. Bauer
Old Oct 30, 2005 | 06:27 PM
GreekGod's Avatar
GreekGod
Your profile lists a '78 F100 so...if that's the blower motor you are referring to then yes, you must remove the heater plenum (the black plastic housing on the RH interior of the firewall) to get the blower motor out. This assumes you do not have factory A/C. My '79 F150's blower died around 70 or 80K miles and the replacement (15 years ago?) was only $15. Don't waste any time trying to get it out without removing the plenum-the squirrel cage keeps the motor in and it's not really too difficult a job.
Old Oct 30, 2005 | 06:57 PM
Mil1ion's Avatar
Mil1ion
The heater moor mounts to the firewall.
You can see it from under the hood.
From under the dash it goes.
Heater Plenum
Heater Core
Heater Motor.
To people who ask about replacing their heater core, I suggest they also replace the heater motor at the same time.
Once you do the R&R, you'll know why
Old Oct 30, 2005 | 08:37 PM
staysbroken
I guess I've got my answer then. Thanks And yes, it's a no A/C truck.
Old Oct 30, 2005 | 08:42 PM
Mil1ion's Avatar
Mil1ion
Does Haynes mention to loosen off the dashboard mounting bolt/nut on the passenger side?
You need to ...so you can pull the plenum out.It's a very tight fit.
Old Nov 1, 2005 | 04:45 PM
1975Ford's Avatar
1975Ford
Here some helpful information. https://www.ford-trucks.com/forums/s...re#post3065023
________
Richard
Old Nov 1, 2005 | 10:10 PM
hotroddually's Avatar
hotroddually
i was given a tip years ago from a old mechanic,he said," before you rip your heater box out ,drill a very small hole in the end of the dimple on the blower motor housing,and us a needle grease tip and fill that hole with grease.it may stop the motors bearing from sqealing."i tryed it,and got a couple more years out of the blower motor.i had to do it a couple times, but it worked for me.try it ,you got nothin to loose,its already noisy and needs replaced,so you wont make it any worse.-billy
mike L
Aug 12, 2014 12:46 PM
John R. Thomas
Jun 3, 2014 06:07 AM
79FordBlake
Mar 10, 2014 10:18 PM
lippsenator
Sep 18, 2010 04:46 PM
cigarxtc
24
Jun 24, 2005 11:44 PM
