1978 - 1996 Big Bronco
radio static
Old Oct 30, 2005 | 03:02 PM
bass4163's Avatar
bass4163
radio static
94 bronco 351...truck has the stock am-fm cd radio just started to pick up static only on the lower fm frequencys...the higher frequencys (over 100) all sound clear...checked everything i could and all connections look clean and tight...while checking cable for antenna found a splice off it that ran up the pass. side piller between windshild and door under the molding and was covered by some foam insulation dident remove the foam cause i dont know what its there for..any ideas...sooo what to check next...would like to know what this (extra ant wire is for and why just static on the lower fm frequencys...mabey just a bad ant or the radio is starting to go........thanks
Old Nov 1, 2005 | 07:03 AM
bass4163's Avatar
bass4163
hello............
Old Nov 1, 2005 | 08:48 AM
muckypaws's Avatar
muckypaws
are there any holes in the cab roof? Maybe someone fitted an extra antenna on the roof at some point?
Seems a bit strange to me!
Simon
Old Nov 1, 2005 | 09:02 AM
RanchRodsTX's Avatar
RanchRodsTX
I wasn't aware they had CD available in '94. The last Bronco I saw with that spliter had the factory hand held CB option. Never really paid any attention to where it went becuase the hand unit and the radio had already been changed out.
bf5113
Sep 27, 2006 10:07 AM
b4hntn
19
Oct 29, 2005 06:25 PM
aleahey
18
Aug 15, 2005 10:36 PM
Longone
Sep 15, 2004 08:48 AM
Fordman4x4
Mar 14, 2004 08:24 PM
