Tail Lights / Blinkers on a 54
Currently my truck has what appears to be aftermarket blinkers added to the front and back. So I have what appears to be a set of rear tail lights from a 56? or newer. These are the "badge" shaped lenses. The wire has a connector with two plugs in the end.
Is this for an integrated brake and blinker?
Also, is there any other blinker style for the front? Right now they are mounted on the front fenders.
(I'm converting to 12v & getting a 'lil side-tracked as always)
on
Originally Posted by jack71
Thanks for the info... I'll have to do some more investigation to figure out how to use these on my 54. I'd like to simplify to a single set of rear lights.
Vern
Jack, there is a wiring diagram here http://www.clubfte.com/users/earl/Re..._Material.html for the "integrated" or 7-wire indicator switch. Maybe you can see if your's matches the wiring. The color codes are for the factory/dealer stock (optional) indicator lights.
gimmeagig
17
07-01-2013 10:33 PM
Roc879
23
03-25-2011 10:51 AM
