Tail lights work Blinkers dont.
Old Jul 9, 2009 | 09:12 PM
Roc879's Avatar
Roc879
Angry Tail lights work Blinkers dont.
Im stuck. 1977 F250 4x4
The headlights and tail lights work.
The blinkers dont.(front or rear)
Hazards work in the front but not in the back.
All the breakers are good.
Grounds in the back are good maybe Im missing one?
Flashers work and there is power to both.
I changed both flashers
Hazard flasher clicks Blinker flasher does'nt.
Any Help would be appreciated
Old Jul 9, 2009 | 09:35 PM
montana_highboy's Avatar
montana_highboy
Turn signal switch maybe.
Old Jul 9, 2009 | 09:46 PM
Roc879's Avatar
Roc879
Oh yeah and I already changed the turn signal switch. Sorry I didnt say that first.
Thank you
Old Jul 9, 2009 | 09:48 PM
hp246's Avatar
hp246
I just went through this with my 76. Very frustrating. I thought I had all the grounds covered. Turned out I had to clean out some thick powdercoating. I would double check all of your grounds, including the bulb sockets. Clean everything up with some sandpaper.
Old Jul 9, 2009 | 09:54 PM
4x4 Bart's Avatar
4x4 Bart
Check the continuity, from the contact points in the socket where the bulbs touch, to the wires coming out of the sockets. This will eliminate the possibility of a bad socket.
Old Jul 9, 2009 | 10:11 PM
ColoradoFordDriver's Avatar
ColoradoFordDriver
Have you been messing with your starter relay? I had similar tail light/blinker issues when i did a wire or two wrong there
Old Jul 9, 2009 | 10:58 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Nothing to do with that, unless you leave ALL of the wires disconnected.
You didn't say if your Brake lights work. Or say whether the bulbs are any good.
Is the Brake light fuse good?
Josh
Old Jul 10, 2009 | 03:04 AM
chapinmesa's Avatar
chapinmesa
I was gonna go with a turn signal switch, I had no brake lights/turn signals on my 73 when I got it, and thats all it was. My '70 had the same issue, but after checking grounds and fuses, they started up working fine. Now I kinda wonder if my '73 even needed the switch.
Old Jul 10, 2009 | 12:33 PM
Roc879's Avatar
Roc879
The brake lights dont work either. The bulbs are good
Thanks for all the ideas guys
Old Jul 10, 2009 | 01:11 PM
Recoil's Avatar
Recoil
I had a similar problem that was blowing fuses.
I just disconnected all the tail lamps, and used the multimeter to put them back together.
It turned out I had a short.
Old Jul 10, 2009 | 02:07 PM
hp246's Avatar
hp246
My money is on the ground. As 4X4 Bart said, get a continuity testor. A cheap one from Harbor Freight will work fine. Check both connections in the socket, grounding each one. If both connections in the socekt show power when properly grounded, you need to look at the grounds for the socket. My 76 is grounded to the assembly itself. IF there is corrosion, paint or powdercoating, it can interfere with the ground.
Old Jul 16, 2009 | 12:55 AM
classicfordman's Avatar
classicfordman
i have a similar problem.....my brake and tail lights work but my turn signals only work when they want too.....most of the time they dont..what could i do right away to try to fix the problem, because it almost got me a ticket the other day...lol..
Old Jul 16, 2009 | 01:09 AM
Bullitt390's Avatar
Bullitt390
Try a new flasher unit... classicfordman. Does the 4-ways act up as well?
Josh
Old Jul 16, 2009 | 01:55 AM
65f100_352's Avatar
65f100_352
I had the same problem with my 78 last year, the back turn signals would turn on, but not blink, and the 4 ways worked on the back, not the front. In my case it was the sockets, which I got new ones from Schucks that are made out of metal, and I think were $10-12 a piece, I'll post up the PN tomorrow.
Old Jul 6, 2010 | 05:03 PM
jcallen85's Avatar
jcallen85
I'm having the same problems
I just bought a 74 f 100 the hazard lights work all four flash. Turn off the hazards and try to turn on turn signal nothing happens. If the headlights are on and you try to turn signa onl a faded arrow comes up but nothing blinks. I'm going to try the ground connects.
