towing limits
Old Oct 27, 2005 | 09:19 PM
Submariner's Avatar
Submariner
towing limits
2003 E 350 extended cargo van, V 10 engine 3:73 rear, factory tow package. What are thetowing limits and do I need a weight dist. hitch for a 7800 lb trailer thanks.
Old Oct 27, 2005 | 09:35 PM
al_e._gator's Avatar
al_e._gator
You need the Gross Combined Weight Rating (GCWR) which should be on your driver's door and then you subtract your van's fully loaded weight to get the towing capacity remaining. If your trailer weighs 7500lbs your tongue weight should be around 750 lbs. Your trailer hitch should have a label on it to tell you if that exceeds the limit without weight distribution. My guess is that your hitch is rated at 5000lbs (500lbs tongue) without distribution and 10000lbs (1000lbs tongue) with distribution.
Old Oct 27, 2005 | 09:44 PM
Submariner's Avatar
Submariner
so what kind of a WD hitch should I get and thanks
Old Oct 28, 2005 | 05:46 PM
rclarke's Avatar
rclarke
Weight distribution is a must with an extended van. Consider using a Reese dual cam system which includes sway control.
An E350 with 6.8l and 3.73 gears is rated for 15,000lbs GCVW and the extended van is rated for a 9,000lb trailer.
Old Oct 30, 2005 | 10:24 AM
Submariner's Avatar
Submariner
Thanks for the help everybody.
Limited_865
2009 - 2014 F150
Dec 20, 2016 09:04 PM
scottman70
Jul 26, 2010 06:39 PM
sb718
2004 - 2008 F150
Jul 13, 2009 06:58 PM
My Limit
2004 - 2008 F150
16
Aug 24, 2005 11:25 AM
GeneStoner
All Things Towing
Mar 20, 2003 09:00 PM
