91 f-150 stalling problem?
Old Oct 27, 2005 | 08:05 PM
hugo69's Avatar
hugo69
Ok so here is the problem I'm having with my '91 F-150 ext cab 4x4. When I start the truck up, It DIES, or when gets to idle it does sometimes, after revving the gas. But then if it does not die at idle, when I but it in reverse or drive it dies. Then if I drive down the road and stop at the stop sign it again dies. The check engine light comes on but then goes off when I drive it a little. Ok so then when the truck warms up it does not do any of this.
Old Oct 27, 2005 | 08:18 PM
Popa Tim's Avatar
Popa Tim
Pull your codes. You can buy a cheap code puller from a parts store or walmart for under $30 or learn how to do it free at www.fordfuelinjection.com
I suspect you IAC is acting up, so If you find your self at the parts store, grab a can of carb cleaner and a Haynes or Chilton manual. They're not great but better than nothing.
Doing a search on IAC should get you more info.
Cheers,
Tim
Old Oct 28, 2005 | 03:18 PM
Mikafinn's Avatar
Mikafinn
Mik
hey: Hopefully you don't have a blown engine, can you smell antifreeze when you start it, do you have to press the gas when you start it? maybe you should have it compression tested!!
Old Oct 29, 2005 | 12:04 PM
hugo69's Avatar
hugo69
So after spending the money and changing the the IAC. I took the codes off the truck and still have no idea what they mean and whats going on. The check engine light stays on until I press on the gas pedal, then goes off. After changing the IAC it does not seem like it is going to choke off. Anyways here are the codes. Can someone please help. Thanks
KOEO (key on / engine off)
63 - TPS circuit has intermittently failed below minimum 0.6 volts.
CM (Continues Memory)
31 - PFE or EVP circuit has intermittently failed below minimum voltage of 0.24 volts.
32 - EVP circuit has intermittently failed below minimum voltage of 0.24 volts.
81 - Air management 2 circuit failure (AM2/TAD).
87- Voltage was not detected on Fuel Pump Monitor while the engine was running.
Old Oct 29, 2005 | 07:05 PM
Popa Tim's Avatar
Popa Tim
You've got quite a few "below minimum voltage" codes... I'd suspect a supply voltage problem over all these sensors being bad.
The TPS (throttle position sensor) you can ohm out before replacinand see if its bad.
Heres a link to testing it; you'll see other sensors listed to the right.
http://www.autozone.com/servlet/UiBr...3d800a2cba.jsp
Tim
Old Oct 30, 2005 | 09:01 PM
hugo69's Avatar
hugo69
What would cause the supply voltage problem?
Old Oct 30, 2005 | 10:45 PM
hugo69's Avatar
hugo69
Do you think it could be the PCM that is bad? The problem of it stalling when putting it in drive or reverse hasn't happened since changing the IAC. But when cold starting I have noticed that it revs up then like its going to stall until I put my foot on the gas. It then idles fine after that. Also I have noticed it seems like I'm loosing get up and go, while driving.
Old Oct 31, 2005 | 01:24 PM
redrush40's Avatar
redrush40
I am guessing you have a automatic trans in your 91.
I also have a 91, had to change the TPS, IAC motor and even my module and magnetic pick up coil in the distributor.
I would guess since you are getting TPS low voltage... hit up your local auto parts dealer and get a TPS sensor.
I had a similar problem, with my TPS sensor, it seemed like it wanted to die after it warmed up and the fast idle came down.
Tell me how it works out then.
TONY Z.
#40
Old Oct 31, 2005 | 03:50 PM
hugo69's Avatar
hugo69
Today while coming into work had the same problem as in the begining. I started it up and it shut-off. Then I tried reving it up and when I put it into reverse it shut-off again. This happened 11 times until I finally turned the truck around in my driveway. But I only live 2 miles from work and it ran fine once I was driving. It did not shut-off at the stop lights or anything. But now tonight after work I know it is going to shut-off until I pop it into drive to get going?
And yes it is an automatic. I still have no idea what to do?
So far I changed the IAC and Fuel Filter.
Need Help BAD!!
Old Oct 31, 2005 | 04:27 PM
Popa Tim's Avatar
Popa Tim
Have you checked any voltages yet?
Old Oct 31, 2005 | 05:58 PM
hugo69's Avatar
hugo69
I don't understand how to take the voltages? The website you sent me to does make sense to me?
Old Nov 1, 2005 | 12:17 AM
redrush40's Avatar
redrush40
If taking voltages confuses you, as it does me sometimes, the best thing is to take it to a mechanic.
Sounds dumb, but ya gotta do it.
But listen to me, change the TPS sensor.
These were known to go in each and every 1990's Ford truck (150 or ranger)!
TONY Z.
#40
Old Nov 1, 2005 | 06:49 PM
hugo69's Avatar
hugo69
I just wanted to say THANK YOU to redrush40 and Popa Tim for all the help you have both given me. Today I changed the TPS sensor and my F-150 runs like new. ( well almost, knock on wood )
Once again THANK YOU!!
Garrett
hugo69
Midnite1987
18
Oct 28, 2017 08:36 AM
OSU_AGR
1997 - 2003 F150
Sep 2, 2012 12:34 PM
Worgus
Jan 14, 2004 08:19 PM
knkdel
1997 - 2003 F150
Apr 28, 2003 07:43 PM
