Sponsored by: Auxito
idling problem
Old Apr 28, 2003 | 10:34 AM
knkdel's Avatar
knkdel
idling problem
I have a 1997 F-150 4.6L V-8 Auto trans w 120K miles. After driving at highway speeds for 15 minutes or so, it will not idle in gear when I come to a stop, and in fact dies. It will idle fine in neutral or park. It acts like it's trying to take off in 5th gear(if it was manual trans) and then dies. This does not happen with city-only driving. I took it to a mechanic who suggested that perhaps the idle control switch was going bad. I had it changed and it didn't help. Someone has suggested this is a torque converter clutch problem. Sounds expensive. Will this intermittent problem show up on the Ford dealer's code tester? Any guesses on repair costs? Thanks.
Old Apr 28, 2003 | 07:43 PM
Racerguy's Avatar
Racerguy
idling problem
Hi knkdel and welcome to FTE
It sounds to me like your torque convertor clutch isn't unlocking. it would be similar to driving a standard and forgetting to push the clutch in when you came to a stop.
I think you're going to have to take it in and get it checked....preferably at a Ford dealer as they have testers made for your transmission.
They can scan the system and see if any codes show up especially for the Torque Convertor Clutch solenoid (TCC).
If the solenoid has failed electrically it should show up on the scanner. If not they will have to do more testing.
Hopefully it is something as simple as the TCC solenoid but it could be more involved like the torque convertor. As for prices I really have no idea. I just fix them..the office does up the bill
69 lil' Red Shane
Jan 24, 2014 10:31 AM
dabigguy
1997 - 2003 F150
May 4, 2012 06:15 PM
aleh61
Aerostar
Apr 8, 2009 04:26 PM
qman
Jan 9, 2006 10:56 PM
grovesr
Jan 5, 2004 09:02 AM
