E-350 starting problems
Old Oct 27, 2005 | 07:22 PM
Lesa's mom's Avatar
Lesa's mom
Hi. I have a 1990 Ford E-350 which usually starts immediately and gives me very little problem. A few days ago, it would not start; it would crank normally, but it sounded like it wasn't getting any gas. So, we disconnected the battery for about a minute and re-connected it. It started up right away and ran fine until today when it will not start again and disconnecting the battery and re-connecting it does nothing. It cranks, but sounds like it is not getting gas. Any suggestions? Thanks.
Old Oct 27, 2005 | 07:26 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 30, 2005 | 09:29 PM
bayou man's Avatar
bayou man
Might be a problem with the glow plugs.
Old Oct 31, 2005 | 02:22 AM
Lesa's mom's Avatar
Lesa's mom
Thanks, but my van doesn't use glow plugs. I'm thinking it might be a fuel pump problem, since it cranks as if it isn't getting any gas. Any suggestions?
Old Nov 1, 2005 | 11:20 PM
bayou man's Avatar
bayou man
Take the fuel line loose and crank it and see if fuel comes out, or take out a spark plug and hold it against the motor and see if it sparks.
Old Nov 2, 2005 | 04:58 AM
Crash687's Avatar
Crash687
can you hear the pump energize when you turn the key forward? have you changed your fuel filter lately?
with a fuel injected vehicle do not pull a fuel line and crank it over as fuel will spray all over the place, the pump is able to deliver fuel at 50 psi.
can you provide a little more info on your vehicle like engine size and if it has dual tanks.
Old Nov 10, 2005 | 08:57 PM
93BigBlackBronco's Avatar
93BigBlackBronco
Start with Fuel pump relay, Front rear tank selector switch, fuel pump if it's not getting gas.
Check ignition switch for power to ignition circuit.
Might be as simple as battery cables and ground my 1990 clubwagon would crank no start, new cables and relay no more headache.
Old Nov 16, 2005 | 07:18 AM
Lesa's mom's Avatar
Lesa's mom
No spark at plug. Cranks and is getting gas. Suggestions???
Thanks for the replies. I took out one of the spark plugs and could smell gas. When we tried to start it, the starter performed perfectly, but the spark at the plug was very weak and irregular. Any ideas??? Thanks for your help!
Old Nov 21, 2005 | 09:39 PM
Gene W's Avatar
Gene W
Are you Mrs. Lupner?
What engine do you have?
How many miles are on it?
Do you have dual tanks?
When was the fuel filter last changed?
How long has it been since it had a tune up? (New plugs, cap, rotor, wires)
When you say that the spark was weak and irregular what did you mean exactly?
What did the plug that you removed look like? Was it black, grey or brown on the end? Was it oily or was it wet with gas or dry?
Gene
Old Nov 23, 2005 | 05:18 AM
racinrob's Avatar
racinrob
a code reader comes in handy. can get on ebay for 15 buck or less. good 2 have around.
let us know if u figured it out yet
good luck,
rik
Old Nov 23, 2005 | 05:27 AM
racinrob's Avatar
racinrob
also, a weak battery can cause trouble. the brain need more amps then the starter.
make sure the neg cable is connected well at both ends.
also always take the neg off first and back on last (on new cars with computers) when diconnecting a batt.
good luck.
rob
Old Nov 23, 2005 | 06:21 AM
Fordcr's Avatar
Fordcr
did we replace the cap and rotor yet?
Old Nov 23, 2005 | 01:41 PM
93BigBlackBronco
One other detail the battery had a dead cell so after a few hours of night driving no start due to battery being weak.
Old Nov 23, 2005 | 04:55 PM
Gene W's Avatar
Gene W
A new battery may solve your problems.
Gene
franky5
1997 - 2003 F150
Jan 25, 2016 09:05 AM
franky5
1997 - 2003 F150
Jan 22, 2016 06:46 PM
johnkirk
May 4, 2010 04:45 PM
Lone Wolff
Electrical Systems/Wiring
Aug 10, 2009 09:41 PM
RogueScholar
Oct 14, 2008 07:30 PM
