Wastegate Question!!!
Old Oct 29, 2005 | 08:21 AM
Kwikkordead's Avatar
Kwikkordead
Yeah, that's not really answering the question. Maybe a call directly to Banks is in order.
Old Oct 29, 2005 | 11:26 AM
jason12's Avatar
jason12
im getting like 28psi of boost out of my truck
Old Oct 31, 2005 | 07:50 AM
bowedup2003's Avatar
bowedup2003
O.K. I tried unplugging the wastegate vacuum hose yesterday, normally I get 15-16psi boost, w/ hose disconnected I got 18psi on level 6. Does that sound about right? I was expecting alittle more with the wastegate disabled. Maybe this is because I did not have a load on the truck.
Also, the SixGun gets its signal from the MAP sensor wiring harness, it plugs in-line between the connectors, no actual connection to the hose.
Bowedup
Old Oct 31, 2005 | 01:47 PM
edub32's Avatar
edub32
Originally Posted by bowedup2003
I get 15-16 psi boost, w/ hose disconnected I got 18psi on level 6. Does this sound about right?
I get the same exact boost without a load so I think our numbers are normal.
Old Nov 8, 2005 | 09:12 AM
02EX73's Avatar
02EX73
Looks like boost comes on faster w/hose disconnected. Rather the using a bolt to put it on, lube (spit) on the hose end and slip it on one of the blank ports on that sensor near it. It looks more factory like as well. I'm seeing about 25-32lbs 2003 EB EX (SC programmer+4" MBPR+AFE 7layer) Now to find out more on trans line pressure upgrads
Old Nov 8, 2005 | 09:32 AM
johnny8's Avatar
johnny8
you want the sonnax tri-cumulator spring kit... one of the best mods i've done on my mule..! helps put all that power on the ground where it belongs..!
sudsmcduff
Aug 7, 2015 10:57 PM
Powerstoke73
Mar 25, 2015 08:08 PM
Crewcab Turbo
Apr 16, 2011 01:08 PM
SNIPER168308
Mar 5, 2011 04:51 PM
