79 vs 81 302
Old Oct 27, 2005 | 11:26 AM
Coop79's Avatar
Coop79
79 vs 81 302
Are there any differneces between the 1979 and 1981 302 V8s that were installed in the F150s? I have an all original 79 F150 and would like to rebuild the motor. I also have access to an in tact 81 motor/transmittion and I'm wondering which one would be better to start with.
Old Oct 27, 2005 | 02:10 PM
Mil1ion's Avatar
Mil1ion
Best place to ask is in the V90* engine forum.
I suspect there is little difference.
Old Oct 27, 2005 | 07:58 PM
just1me's Avatar
just1me
this is what i found sorry.
1979- 302 2v has 8:4:1 cr 135 hp @3400 rpm and 243 ft lbs@2000rpm
1981- 302 2v has 8:4:1 cr 137 hp @3600rpm and 239 ft lbs @1800rpm
they are pretty equal but id go with the 81 model and just maybe bump the timing a bit, and go with a 4barrel and dual exhaust.
Old Oct 28, 2005 | 05:37 AM
four-sixty-power's Avatar
four-sixty-power
The engine mounts should be the same, not sure about the wiring though, rad hoses from the 79 should be used if the 81s are different, fanshroud from 81 would prob be different-use 79, air intake from rad support may be different so use your 79 aircleaner and ducting, check how the exhuast is routed - are the manifolds different?
basically look over both set-ups and see what is different and what you can swap
I swapped a 79 T-bird 302 into my 77F150 and when I ran that eng into the ground I swapped a 79 Granada 302 into its place, I used all my trucks wiring(which was originally for a 460!) and the air cleaner was cleaner from the Granada so I didn't use any air ducting - it just drew air from under the hood. I had to swap frame mounts from the 460 style to the 302 style though and "customize" the driveshaft to work with the T-bird tranny
the truck left me in August.....
Last edited by four-sixty-power; Oct 28, 2005 at 05:38 AM. Reason: had to change sumtin
Old Oct 28, 2005 | 08:42 AM
LxMan1's Avatar
LxMan1
Either is a direct bolt in.
lumbertj
Mar 16, 2013 08:44 PM
Todd's81ford
Oct 21, 2011 02:44 PM
79-400-POWER
Engine Swaps
Jan 24, 2008 10:24 PM
oldhalftons
Dec 3, 2003 06:40 PM
yak
Sep 1, 2003 11:10 AM
