I have a 1979 f150 4x4 with a 351m that has been borded out .040 and a few more small odds and end done to her. My question is how can I get more torque out of my truck? I have the factory c-6 with the 9 inch rear. I have this rebuilt engine but not enought torque.
Toss in a 400 crank and a beefy cam (you didn't mention that was done). Other than that, your C6 is eating up about 25% of what that motor is putting out... If you have changed your tire dimensions, you may also want to consider gear swapping in the rear end. It's a little cheaper and less time consuming than a motor tear down
OK, so I partially retract my statement about the C6 drawing 25% power.
It seems that it's ~20-25% on a STOCK engine. It's not exponential, and I didn't intend for it to come accross that way.
From what I've read and heard it seems to be in the order of ~60hp.
it is really around 20 to 30 hp a manual consumes power too but not as much.
The C6 does not draw 25% of engine power. It does, however use up to about 25 more HP then a C4 or an AOD. Sadly, custom bellhousings to mate a C4 to a 351M are scarce (C4's are much tougher then most think).
The 400 crank will fit the 351, but you'll need the 400 pistons as well (the 351 pistons won't work-they will sit too high in the bore). Both use the same rods. It's a good idea, as anytime you increase stroke, you increase torque.
