Mustang Block ok for Explorer?
Old Oct 26, 2005 | 11:18 AM
CarlsonCustoms's Avatar
CarlsonCustoms
I have a friend that has many 302 blocks from mustangs that I can use to rebuild and then swap with my explorer 5.0 but does anyone know if they older 302 blocks are EXACTLY the same as my 96 explorers as in bracket holes, sensor holes etc etc?
Thanks
Zack
Old Oct 26, 2005 | 02:36 PM
CobraXP's Avatar
CobraXP
Should be the same. Depending on heads, etc - you could run into differences there, but that will happen depending on what heads you use anyway. Block for block - you shouldn't have anything to worry about. Get one of them and stroke it...
Old Oct 27, 2005 | 09:42 AM
CarlsonCustoms
Well I was probably gonna use my stock gt40 heads that would be freshened up.
i would like to stroke it but those kits are expensive.
Old Oct 27, 2005 | 09:54 AM
CobraXP's Avatar
CobraXP
Easy setup if you have access to the block: have it bored to a 306 and have the GT40 heads match ported and polished with the intake. Would not cost all that much if you had a pretty good machine shop around.
Old Oct 27, 2005 | 08:44 PM
CarlsonCustoms
dont you need new crank , rods and pistons too though? having it bored to 306 wouldnt be stroked.
kb-65
Sep 14, 2006 06:12 PM
Weaponrider
Sep 5, 2006 07:27 PM
1yamman350
Jul 23, 2004 12:33 PM
dunnit52
Dec 16, 2002 05:29 PM
