Rebuilding Front Axel
Old Oct 26, 2005 | 08:56 AM
429 78 F100's Avatar
429 78 F100
Question Rebuilding Front Axel
I am restoring my 78 F100 and have taken the cab and body off the frame to have the frame cleaned up and painted. My question is was there a piece of felt type material behind the backing plates on the front axels. My friend took the front end completly apart and said the only thing he cant find was those pieces of material. What was this for? Not shown in the book that I have that gives you a blown up view of the assemly. Does any one know where I can get this or the material it is made from?
Old Oct 26, 2005 | 11:03 AM
1975Ford's Avatar
1975Ford
Is your truck a four wheel drive or two wheel drive?
Old Oct 27, 2005 | 06:10 AM
429 78 F100
That would make adifference. Two wheel drive.
Old Oct 27, 2005 | 08:16 AM
1975Ford's Avatar
1975Ford
Yes, I have seen this on two wheel drives, I don't know where one could this material, but something similar to the canvas looking material might work if you decide to go with some sort of material.
Old Oct 27, 2005 | 11:03 AM
429 78 F100
Do you think this is just a gasket of sort to keep it from being metal to metal?
Old Oct 27, 2005 | 11:16 AM
1975Ford's Avatar
1975Ford
I think you're right, some type of gasket or paper material. That what I was thinking also, an anti vibration for the dust shield, maybe to minimize noise travel and noise resonation to the dust shield, not sure what the engineers where thinking when they put those.
Old Oct 27, 2005 | 12:05 PM
429 78 F100
Well for the time being I'm going to go with that idea until I here something different. I stiil have the brake lines and rear brakes and other parts to put back on before I need to do that. I have a bear black frame with front and back axels under it.
Thanks
Old Oct 27, 2005 | 12:11 PM
Mil1ion's Avatar
Mil1ion
First off a Head's up !
FTE has a drivetrain forum for questions like this.
Are you sure it is felt ?
Is the part a little hairy ?
Could it be swelled paper ?
I think I have the last paper gaskets for axles in captivity (in Canada that is).
Old Oct 27, 2005 | 12:19 PM
429 78 F100
I dont know if they were felt or paper and the guy that took it apart said he took it apart so he could do a better job at painting it. He said he new there was a gasket of some type but couldn't remember but he new there was a gasket there and couldnt find it when I went to pick it up. Do you know?
Old Oct 27, 2005 | 12:23 PM
Mil1ion's Avatar
Mil1ion
I have about a 100 of the paper gaskets that go on the end of the axle tubes behind the backing plate.
I'll search my Ford book to see if they put felt gaskets there as well.
Old Oct 27, 2005 | 12:35 PM
429 78 F100
Time to leave in a few minutes. Thanks for checking on this. I'll log back on later to see what you found out.
adammdennis11
Oct 29, 2013 11:26 AM
Outlaw56
27
Aug 7, 2013 08:47 AM
Ness57
Jul 14, 2013 10:39 PM
xingfool
Jan 23, 2004 04:32 PM
sed8ed
Sep 18, 2002 11:23 PM
