Sponsored by: Kumho
Emergency Brake
Old Oct 25, 2005 | 05:18 PM
James W. Hitch's Avatar
James W. Hitch
Emergency Brake
What is the most comon reason for a faulty emergency brake?
1982 F-150
Old Oct 25, 2005 | 06:41 PM
darrengj's Avatar
darrengj
the cables are seized
Old Oct 25, 2005 | 08:10 PM
James W. Hitch
Yes I believe that is the problem.Where is the problem?
Old Oct 25, 2005 | 08:16 PM
fordborn's Avatar
fordborn
Thread moved to "Brakes, Steering, Suspension, Tires, & Wheels" tech forum. Should receive more answers here.
Old Oct 26, 2005 | 05:23 AM
stuart1's Avatar
stuart1
Wherever they are seized.
Old Oct 26, 2005 | 10:01 AM
James W. Hitch
You cant tell me where they are siezed?There has to be areas **** to this type of problem.There siezed is really not a helpful answer I already new that when I started
Old Oct 26, 2005 | 10:29 PM
pmasley's Avatar
pmasley
One is streched cables and the other is siezed parts.
The cables can be adjusted by the lock nut on the drivers side just behind the cab.
The cables usually sieze just as they enter the rear of the brake drum. Another problem is if the parking brake bar is rusted tight on the shoes. A minor teardown on the rear brakes is needed in order to find the sieze point. All park brake parts should be loose and be able to be freely moved with a screw driver inside the drum.
Old Oct 26, 2005 | 10:54 PM
rhodie's Avatar
rhodie
From my limited expecience, it seems like the driver's side tends to be the first to seize. Usually you find that the equalizer is kinked as only the pass. side is working. You're porbably better off replacing the seized section, usually about $30+ each.
Old Oct 27, 2005 | 09:59 PM
James W. Hitch
Thank you very much.This helpful info.I plan to resove this problem this weekend I will let you know how it comes out
Old Oct 27, 2005 | 10:57 PM
someday's Avatar
someday
i usually tug on the part that goes from the cab (1 wire) to where it splits off to each brake. the cable(s) should move in and out of the sleeve, if not trace it to which side and disassemble brake and see if you can move the p-brake lever...if that moves the cable is seized and should be available at the parts store
it could be way out of adjustment(connecting cables or brakes) or even a broken cable
Old Oct 28, 2005 | 08:38 AM
stuart1's Avatar
stuart1
I have seen them seized anywhere from the actuator in the cab to the rear assembly.
Bofronado
15
May 4, 2020 09:42 PM
Oldschool2888
Apr 26, 2016 11:27 AM
GTO-Ron
20
Sep 13, 2015 04:28 PM
HILLBILLY BOB
Aug 21, 2015 02:37 PM
rtilton
Jul 7, 2008 11:31 AM
