Emergency Brake Adjustment
Old May 16, 2005 | 11:33 AM
GTO-Ron's Avatar
GTO-Ron
I own a '99 F-350, CC, Long Bed with the 7.3 PSD. The emergency brakes do not hold the truck. With the emergency brake pedal depressed it does provide some resistant but not enough to hold the truck.
How do I adjust the emergency brakes
Old May 16, 2005 | 11:52 AM
bug juice's Avatar
bug juice
How do I adjust the emergency brakes[/QUOTE]
These brakes are only parking brakes, in no way would i trust them in a emergency situation. I have taken the shoes completly off and cleaned everything up and adjusted them to find out a few weeks later I was saying the same thing as you did...[QUOTE=GTO-Ron]it does provide some resistant but not enough to hold the truck....especially when it is in gear.
Adjust just like anyother brake shoes, remove rubber plug on back side of brake backing plate, use a screwdriver or brake adjusting spoon. Turn it unitl you hear it drag and back off until it does not drag. If I remember correctly you move the spoon tip/screwdriver in the down direction on both sides to tighten brakes. Clockwise on driver side looking back towards front of vehicle and Anti-Clockwise on passanger side looking back towards front of vehicle.
Old May 16, 2005 | 12:03 PM
gseeders's Avatar
gseeders
There is a slot on the back side of rear wheel drum. Use a flat blade screw driver and turn the adjuster that u can see in the slot, you should hear clicks as you turn that adjuster. count the clicks and repeat on other side. be carefull not to over adjust.
gseeders
Old May 16, 2005 | 07:29 PM
01psd's Avatar
01psd
gto ron, hi on my e-brakes what I did was tighten them up until you get a good drag on the wheel then just back them off until you cant hear them touching . mine hold real good. mine is 2001 but I think there the same set up. you really cant adjust both wheels the same amout counting clicks because chances are they are not the same. just my opinion. 01psd
Old May 16, 2005 | 08:11 PM
truckman87's Avatar
truckman87
Hey GTO-Ron, do you have a gto or just like them??
Marc
Old May 16, 2005 | 09:49 PM
GTO-Ron's Avatar
GTO-Ron
I have a 1965 GTO that I drive on the street and race also.
Old May 17, 2005 | 12:23 PM
truckman87's Avatar
truckman87
nice, i have an all origional 1966 with tri-power and a 4spd. best cars around!!!
Marc L
Old May 17, 2005 | 12:35 PM
GTO-Ron's Avatar
GTO-Ron
Do you belong to any of the Pontiac Clubs such as GTOAA or POCI??
Tri Power....How cool is that!!
Old May 18, 2005 | 02:13 AM
wfmcbride's Avatar
wfmcbride
GTO,
I use the emergency brake before I put the tranny in park to prevent any load being applied to the tranny (I come to a complete stop and put the tranny in neutral first).
However!!!!!!! I was on a slight grade with a trailer one time and broke the front cable trying to stop the truck from rolling, it was the short cable that goes from the pedal to the long cable on the underside. About a hundred bucks worth of short cable.
Now I have the wife get out and block the tires if I'm on a grade with a load, or I find a flat spot.
Old May 18, 2005 | 06:50 AM
glafond's Avatar
glafond
Talking
Wow, no matter how hard I try, I just can't get my wife
to crawl behind the tires.........
Old May 19, 2005 | 02:43 PM
wfmcbride's Avatar
wfmcbride
Try this one
Hey honey I think I dropped my wallet in front of the rear tire on your side!
It worked for me the first time.
Walt
Old May 19, 2005 | 07:10 PM
fixnair's Avatar
fixnair
If the 99 has disc brakes on the rear then your E-Brake is a small drum brake inside the disc. My E-Brakes stopped working too. When I took things apart to find out why I found the axle seal to be leaking oil onto the brake shoes. Bought new shoes and seal. Be sure to refill the differential with new oil!
I weigh 12,200 Lbs. as she sits and the E-Brake will hold on a moderate grade but I wouldn't expect to stop it while moving.
Old May 20, 2005 | 10:15 AM
wfmcbride's Avatar
wfmcbride
Smile Thanks Fixnair
I learned something again!!!!
Old May 20, 2005 | 06:07 PM
GTO-Ron's Avatar
GTO-Ron
My truck has disc brakes in the rear. Over the holiday weekend I will take the rear brakes apart and see what is going on.
Thanks everyone for the replies.
Old Mar 7, 2009 | 10:42 AM
hosemandc's Avatar
hosemandc
Im having parking brake problems too. The other day I went to get coffee leaving my truck running and ended up finding it in the middle of the road stopping all traffic. A few months ago I backed my 31 ft trailer into its parking area, place the truck in neutral and put the brakes on. When I unhooked the trailer from the truck.....yes here it comes... the truck proceded down the hill to rest against a tree. $3500 worth of damage.
I have taken the brakes apart and replaced all parts. Put it all back together and adjusted the stars. Did the back up adjust trick. Tried everything. What is next? Replace all cables?
Thanks
