2002 E450 drive shaft emergency brake
Fords troubleshooting for the E450/550 parking brake assembly is... limited.
Basically, check the cable. If its not broken, out of adjustment, or popped off, you replace the whole assembly. There are certain parts available (shoes and springs). You should also check to make sure there is ATF (which is used as the hydraulic fluid) inside the parking brake assembly. Other than that, replacement is really the most straightforward option unless you are a full service shop with a lift and press.
Replacing the parking brake assembly requires dropping the drive shaft. I have attached the Ford Service Manual sections of interest.
http://www.filedropper.com/superdutyparkingbrake <- Pinpoint Tests
http://www.filedropper.com/superdutyparkingbrakernr <- Removal and Installation
http://www.filedropper.com/superdutyparkingbraketension <- Adjusting the Cable
To use the above links, click 'Download this File' in grey. These are PDFs and will require adobe acrobat reader or similar.
For diesel vans, the parking brake assembly is around 1300 bucks. If you want to go junkyard hunting, I THINK the 90-97 F-Super duty trucks used the same brake, as well as the 96-04 E-Super Duty and the 00-04 F450/550 if they were chassis cab.
Thank you for the input. I still don't have it fixed, but the $1500 fee seems pretty steep for my bike club. I did find this link of taking the unit apart. I don't have a complete shop. Is it possible to service the brake pads and check linkages without pulling the whole thing apart and removing the bearings.
I have rebuilt a bunch of these and yes it comes apart, and no the video skips a few steps. Ford still does make the parts to fix it just did one a few months ago. They do burn up easy if the e brake light doesn't come on and someone drives it. I don't think the ford manuals show you how to fix these, replace as assembly but they have the parts. I see your not in a hurry so if you want to fix it I can give you pointers to help.
We have taken off the drive shaft and the 4 nuts that go through the drum assembly, but still can't get to the brake pads. I would like to just get the drum off to look at what is going on with the brake, as it has no resistance when activated. I have a diagram, but it is not clear if I can just service the brake shoe assembly without pulling the whole unit or not. Have it soaking in penetrating oil for now and will reassess later in the week.
If you can tell me A) Can I get to the brake shoes without pulling the unit and ripping in all apart, and where I can get parts, I would really appreciate that. Thanks
A) No you can't get to the shoes in the truck. B) Ford should still have the parts, you will need the shoe assm which is shoes, springs and backing plate and the 2 seals. You have to remove the whole thing, drain the oil out using the fill plug. Then you remove the large nut facing the trans. then it gets fun, you need a second person to hold the housing and then with a large plastic hammer or using a 2x4 and hit the end where the big nut was to push the center shaft and drum through the housing. It sounds caveman like but you can't press them apart because the drum is bigger than the housing. after that its easy the backing plate just bolts to the housing and most likely you will screw up at least 1 of the seals just replace both. I can check with my ford guy tomorrow on availability. I may even still have one extra.
E450 Emergency Brake
Hopefully since this thread is 5 years old and not solved I can do another little bump.
I'm taking my ebrake off and can't seem to get the ebrake cable housing to break free from the bracket that holds it on the assembly. Looking at my new one seems like it has a lip for some type of latch that holds it in. Is there any secret method to get those out?
im having the same problem, what’s the trick to getting the cable off the zf brake housing ?
I can sort of help
Somewhere I still have the diagram of the unit on paper, but it is in the shuttle bus 40 miles away.
