Can anyone explain what a torque converter does?
Extra,Extra ,read all about it >
Right here >
http://www.howstuffworks.com/torque-converter.htm
BTW, I have numerous sites like this linked from my web site.
Drop around sometime.
[b][i][font color=red]Dennis[/font][i][b]
[font color=red]Calgary,Alberta,Canada[/font]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=green]Do You Need To Decode Your 78 Truck Data Plate?
[/font
http://www.clubfte.com/users/mil1ion/FordTruckCodes.html
[font color=red]If New Ford Parts Is What You're Cravin',
Then Buy Them HERE,At Motorhaven![/font]
[font color=green]Please Feel Free To Visit My Website.[/font]
http://www.clubfte.com/users/mil1ion/Mil1ion.html
[font color=red]
Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V [/font]
I'm not a mechanic, but that's the way I understand it. If anyone here has a better explanation, please correct me.
Hightlite > Copy > Paste > Go.
And up comes the page.
Have a read!
[/font
[font color=red]
Stall speed is the point were the engine can no longer rev against the transmission when the brakes are applied. The fluid action of the convertor holds the engine (or stalls it) at one rpm level. When you release the brake the engine revs like bat out of hell and the car launches. Guys at the track around here call people that use the brakes "footers". I run a bracket class were only footers are allowed.
The guys that do it at the digs (drag racing that is) on weekends that have engines strong enough to over come the brakes will use what is called a "trans brake" to hold the engine at stall. What a trans brake does is engage both first and reverse by applying fluid pressure to both clutch packs at the same time. When the yellow light glows you hit a little switch on your shifter and the selinoid that was holding the pressure to the reverse gear lets go and your flying.
Then you have what is called the convertors "flash stall speed". When you drop the tranny in gear while holding your foot on the floor the rpms that engine drops to is known has the converters flash stall speed. This sounds like its pretty rough on the tranny but if it's built right it's no worse then dropping the clutch at 6000 rpms on a strong manual.
The flash stall is always higher then the real stall speed. People do the flash thing because it delivers a whole lot of torque to the tires in a flash. This "loads" the rear springs and traction bars and forces the car to "sit" on the rear tires. The engine is then "pulled down" to the stall speed and races backup the rpm's. The big trouble here is tire shake. When that happens you lose the "load" and your tires are up in smoke.
Because a torque convertor is a fluid connection it can never really "lockup". There is this freaking thing called the laws of phyics, that says you can't have conservation of energy, and something else about the laws of fluid in motion that says it just can't happen. Because of these unbreakable silly law convertors generally slip on the range or 3-5% for a factory job and as low as 1.5 % for a really tight after market.
But that doesn't mean there are not lockup convertors. Starting in the early 80s some great person (that probably didn't get paid enough) came up with the idea of using a electric-magnet in the convertor to "lock" the engine and tranny together. Next time your driving your 4 speed overdrive count the number of shifts it fells like its making from a stop to 55 mph. I'll bet it makes 4 "shifts". Thats because somewhere (normally around 20-25 mph or just before the 2nd to 3rd shift) in there the convertor "lockedup". Has you slow down the tranny tells the covertor to unlock so you wont stall the engine when you stop at the light.
Ok I think I kind of overstayed my welcome on the topic. I hope this answers the questoin for ya. Sorry for the novel but I haven't slept in 38 hours and I just can't seem to shut up lol.
PS Examples of convertor size to stall:
Factory 12" 1200 to 1800
Factory 11" 1800 to 2400
After Market 11" 1800 to 2800
After Market 10" 2500 to 3500 some are 3800 depending on stator design
After Market 9" 4000 to 5000
After Market 8" 4500 to 5500
A convertor will not stall at the same speed behind a 351 as it does behind a 460. The reason is engine torque. The more torque an engine makes the higher the stall speed for same size convertor.
For example if you have 250lbs of torque on 351 and the convertor stalls at 1400 that same convertor would stall at 1800 behind a 460 with 300lbs of torque.
And last but not least is vechicle weight. The more a truck weighs the higher the stall speed for the same convertor. If you yanked a 302 out of a stang (weight of ohhh 2800lbs) and the convertor stalled at 2800 when you drop the engine in the truck the stall would be around 3500 rpms. It's because the engine has to make more torque to overcome the resistance of the extra weight, so ya need more rpms (power) scotty.
Drop that bottle of whiskey, wait...no...set it to the side...gently...
Man the dilithium crystals and BEAM ME UP !!!!!
Texas Bird :+
Daddy's First Car Was A Model T--He Bought It Used For $11.50 And Drove It Home
1979 F150 Custom--Betsy--302 2V, 4sp.OD(RUG)
1978 F150 Ranger XLT--Snuffy--400 2V, C6
