WHich one to Keep
Old Oct 25, 2005 | 10:48 AM
69crewcab's Avatar
69crewcab
WHich one to Keep
Ok group Heres a story i Need help with..
I needed a plow truck for my driveway this year(bought a new home)
so I decided to go with a 73-79 F-250 for years
Well my first truck i come across is a 78 F-250 4x4 Crew cab with a rebuilt 351m and a c-6
I buy it and tell the wife i can get a plow for it ..truck is driveable
but need body work.
Well i look for a plow setup and what do i find but
a 79 F-250 4x4 Supercab with a western plow setup, a 460 and a 4speed
truck is rough but driveable so i buy it
Now my dilema
I need to sell one, and keep one for a plow truck..
What do i do??
Old Oct 25, 2005 | 11:06 AM
77bigblock's Avatar
77bigblock
I would keep the one with the 460. As long as your feet don't drag on the ground, who cares what a plow truck looks like. If you don't mind the clutch, and the 460 isn't too tired, it will push better than a 351M. In my opinion, a 351M isn't good for much except making you poor. They aren't known for their gobs of power.
Old Oct 25, 2005 | 12:27 PM
77300i6's Avatar
77300i6
You have to sell one but don't know which one. That's easy!!
Take the 460 / 4 spd out of the supercab and drop it into the crew cab. It couldn't be easier since you have ALL of the neccesary parts right there!!!
Then put the 351M / C6 into the supercab.
If you prefer the 460 w/ the C6, it will bolt up because the 351M & the 460 have the same bell housing bolt pattern (same goes for the 351M/4spd combo). Although, I would have the C6 rebuilt for insurance incase it's on it's way out.
The F250 supercab probably came with a 351M/400 anyway, so loss there.
I don't like autos , but for plowing, it may be a better tranny. Just use a tranny cooler and a deep pan.
If you have a little time, it's pretty much just a matter of swapping everything from one truck to another.
This way, you keep:
460 (much better for power)
manual or auto (it's up to you)
Crew Cab (they are becoming quite rare)
Sell the F250 supercab w/ a 351M and the tranny you don't want. Simple as that. The plow will bolt up to the CC frame. You said the bodies are rough, so really, no call there. I would also see what else you might be able to take from the truck your not keeping to fix/upgrade the one you do.
That's what I'd do anyway.
Old Oct 25, 2005 | 12:55 PM
77bigblock's Avatar
77bigblock
77 300 I6 put it very well. Do what he says.
Old Oct 25, 2005 | 01:39 PM
Slow's Avatar
Slow
Keep them both! Good to have a parts truck!
Old Oct 25, 2005 | 02:56 PM
User 71024's Avatar
User 71024
I'd want the shortest truck to plow with unless your plowing in a straight line.
Old Oct 25, 2005 | 03:10 PM
77300i6's Avatar
77300i6
You're right about that. A bronco would be best, other than the 1/2 ton frame.
If he just has a long driveway to plow I think the CC would be ok. Whether it be the supercab or CC, either way, they both have the turning radius of an aircraft carrier.
Old Oct 25, 2005 | 03:17 PM
highboy1975's Avatar
highboy1975
thats a tough one, theyre both pretty rare anymore. either of them have a dana 60 front?
Old Oct 25, 2005 | 03:19 PM
77300i6's Avatar
77300i6
I would bet the farm the crew cab does. The supercab, maybe.
Old Oct 25, 2005 | 03:35 PM
highboy1975
i dont know, i've seen quite a few crew cabs with 44 fronts. 69crew is gonna have to check it out. i'd set a truck up crew cab, 4spd, 460, and dana 60 out front. that would be my keeper right there
Old Oct 25, 2005 | 10:24 PM
hotroddually's Avatar
hotroddually
a man should never have to pick one ford or the other.thats like sayin,which one of your kids do you like better.lol-billy
Old Oct 26, 2005 | 07:30 AM
77300i6's Avatar
77300i6
That's the the way I'd go about it. I'd also choose the best bed of the two. I'd take the best of both trucks and put them into the crewcab, the put the other truck back together with what's left, sell it, and convince the wife that the truck I kept needs repairs.
Old Oct 26, 2005 | 08:19 PM
69crewcab's Avatar
69crewcab
they both have 44's up front, i was hoping one of them had a 60 up there.
I do like the idea of the 460 in the crew with an automatic...hmmmm
Now i just need the time to do the swap
Can i use the 351m flexplate on the 460 or do i need to find a 460 flexplate
for the c-6?
Old Oct 27, 2005 | 07:22 AM
77300i6's Avatar
77300i6
I believe that you will need the flexplate for a 460. I think they have a different imbalance. The starter will work though. Check in the 385 series forum as well as the 335 series forum. All the info you need will be there.
