Thought I'd give this question a try here as well,
I bought a stock '73 390 2 barrel and was wondering what the HP rating of these engines are. The door tag on my truck says my 360 has 175 so I'm curious about the comparison.
Just a guess on that smog era motor... I think they were advertised at 230, so about 195 ought to be right in the park, depending on the accessories mounted up and the tranny used.
I saw an owners manual recently for a 1971 f-250 that rated the 390 2v at 255 h.p. and 375 ft.lbs. torque.
I don't have any documentaion on this now but my father bought a new 65 Thunderbird and I still remember him saying it was a 390hp 390ci. Maybe it was and maybe it wasnt thats just what I remember him saying
remember in 1972 ratings went to SAE instead of gross. Sales, insurance, drag racing all influenced factory ratings back in the day. The 1970's were a dark age for performance, more so about mid 70's, the 302,351w barely around 140hp, the 460 had 212 in 1978, the 400 ranged from 160-180hp.
Fairlane GT's, with 428 cams and better manifolds were rated 335.
There were no 390 horse 390s.
The only 390 horse rating I can recall is for the extremely rare hydraulic lifter 427 in a '68 Mustang.
All these were the old gross HP standard.
By '73 they went to a net standard, where the accessories like the water pump and fan and alternator, the air cleaner and stock mufflers were on the engine for its rating. Thus, the numbers went down.
A truck 2bbl 390 with lower compression, single exhaust, net ratings--probably like the previous post said, somewhere around 200.
'73 390, 2bbl, 8.2:1 was 161HP@3600, 299ft/lbs@2000
'71 390, 2bbl, 8.6:1 was 255HP@4400, 376ft/lbs@2600
In '72, they changed from GROSS numbers to NET numbers, which is the reason I gave you the '71 figures... chances are, the '73 probably puts out the same gross numbers as the '71.
Here's some more from a Motor's Automotive manual, going back to '67:
'67 390, 2bbl, 9.5:1 was 265/275HP@4400, 401/405ft/lbs@2600 - there were two different ones listed, same compression
'67 390, 4bbl, 10.5:1 was 315/320/335HP@4600/4800 and 427@2600/2800 - there were three different versions.
Well, keep in mind the rediculously small camshaft used, the low compression, and the low-rpm's where peak torque was made. Add to that the restrictive truck exhaust manifolds, and 2 barrel carburetor. Then, the numbers start to make sense. The cylinder heads never had a chance to do what they were designed to.
A few months ago, I had the opportunity to drive a guy's F250 from down the road. It has a bone-stock 360, truck manifolds, 2 barrel carb, and all. Starts up RIGHT NOW, and runs great, but has no power. I made him a custom throttle bracket, and we messed with the timing a little, and that helped a little. But still, the word dog could be used. So I believe those numbers. Then he had a chance to drive mine.
That's why we're here on the FE forum, to get those numbers up!
