Stock 390 HP?
Well, obviously I like the numbers off that ’71 better. Hopefully the ’73 was at least close in gross if not the same.
What’s odd though, is cleanLX’s door tag showing only 180HP with his ’69 390 and my ’69 360 showing 175HP. Only 5HP difference between the two motors? And that’s quite a bit off from the book showing 255 in ’71.
Thanks for all the info everyone! I have a cam question too, but I’ll start a new thread for that.
-CE
-CE
I have a 73 F100 that was the stock 390 when I got it. I was thinking the stock hp was 185...I could be wrong though....I know this...for a 390 it was a dog. It ran just fine...just didn't have the neck jerking power I would expect from a 390. As many others have said, it's easy to turn it into a screamer.
Tracy
Tracy
on
1 Post
Originally Posted by Bear 45/70
From '67 thru '70 there was a Premium fueled 2V 390 that made 280 hp and that is probably it as there was never a 180 hp 390 or even a 352 in the '60's. There was 375hp 390 4V in '61 and '62. There as a340 hp 3X2V 390 in '63 and a 401hp 3X2V 390 in '61 and '62.
Now, all those engines you speak of.... were they truck engines or car engines?
I thought all the truck FE's were down around 8.2:1 compression?
I'm not positive but I also think all the trucks were low compression engines. The 60's car 390's are a different story. My dad had a 66 galaxie 4 door sedan 390...a family car...it was stock 330 hp. The car sat for years on the farm till he finally had a junkyard pick it up...I wish he'd have kept that engine.
Those were the car motors. The 1960's light truck engines were 360 was 8.4 CR and 215 hp @ 4400 and 327 ft/lbs @ 2400. The 390's were 8.6 CR and 255 hp @ 4400 and 376 ft/lbs @ 2600. The 361 and 391 were weaker yet, 361; 7.4 CR and 210 hp @ 4000 and 345 ft/lbs @ 2000. The 391 was 7.4 CR with 235 hp @ 4000 and 372 ft/lbs @ 2000. Then of course there was the 361 Edsel motor at 303 hp @ 4600 and 400 ft/lbs @ 2800. The compression was 10.5 :1 in '58 and 9.6 : 1 in 1959.
Oh please don't be fooled by those low numbers.
390 FE engine in general can make a real ground pounding stump jumping truck engine. In late 60's 390 mustangs could be beefed up easy to run in the 12's
Just a little work and it will surprise ya.
Rusty is right, about the low compression restrictive exhaust.
We are in the middle of beefing up my sons 390 in his 76 4x4.
I expect some real improvement.
I owned a 428 CJ in my youth. And it may surprise some to know that the early 428 CJ, actually had 390 GT heads.
You put GT heads on that 390 and some headers, large exhaust pipe. Pick a good camshaft based on your driving needs. And i think you are going to think you awoke a sleeping giant....
LOVE FORD BIG BLOCKS
including 385 series
Bear
I think you misunderstood my post...
I was saying that the 390 that were beefed up...
Although it would have been nice to have a 390 Mustang or any engine in a mustang that went 12's out of the box.
The point i was making is that the low published number that was being discussed. Shouldn't scare anyone off a FE block.
Oh and I did check my research and your right it was the 427 head....(sorry for error)
This little note highlights is about a Mustang back in the day
In 1967, Popular Hot Rodding acquired a 390 Mustang GTA fastback as a project car. With a C-6 automatic and dead 3.25 gears, they baselined the car at 14.10 @ 100 mph. For the next six months, they changed gears, intakes, carbs, cams, headers, tires and a variety of other items that you or I might swap out on our cars, that transformed the car into a truly fast street machine, eventually posting a best of 13.29 @ 103 mph. All during the test, the project Mustang GTA remained a daily driven street car reliably bringing its driver to work and home every day while leaving the shifter in drive. On the weekends, it was a nasty race car that won more than it's share of races. Month after month, the author stated that the 390 GTA was not only competitive but embarrassed many cars with bigger engines. After 17,000 miles and 350 passes down the track, it was retired.
Bear
#29
In 1972 the horsepower rating game changed, all the numbers dropped a bunch. Prior to 1972 a 390 pickup truck motor was rated at 276 hp @ 4400 and torque was 376 @ 2600 but there were no truck 4 barrel engines, all 2 barrel with an 8.6:1 compression ratio. A 390 car motor with 4 barrel was 300 hp @ 4400 but the compression was about 9.5:1.
#30
