E100 Automatic Transmission Swap
Old Oct 24, 2005 | 12:27 PM
cornfed937's Avatar
cornfed937
Hello, I just bought a 1965 Econoline pick up with a very sloppy 3 speed tranny on the column, that I would swap out with an automatic. Does anyone have any idea what A/T would bolt up? Would a C4? Has anyone done this swap? How much work is it?
Old Oct 24, 2005 | 03:54 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 24, 2005 | 06:37 PM
61ford's Avatar
61ford
id go post that question a few forums down in the ranchero and econoline forum they should be able to help you out better down there.btw welcome to fte
Old Oct 25, 2005 | 06:31 AM
jowilker's Avatar
jowilker
61ford, While generally that is a good suggestion, that forum doesn't get the traffic that this one does. As long as he is asking general 65 year questions, let's see if we can help him here. More specific E questions sould be directed to the Ecno forum.
Howboutthat?
John
Old Oct 25, 2005 | 08:35 AM
PROSTOCK's Avatar
PROSTOCK
cornfed, we can and would like to help, but we need to know a little more info, like what engine you have, if you have power steering, etc.
Just becouse you may not be in the "right" forum doesn't mean anything.....these guys here are geniuses!!!!!
Old Oct 25, 2005 | 11:25 AM
61ford's Avatar
61ford
i just thought since he was talking about an econline they might know more about it down there.sorry just trying to help
Old Oct 26, 2005 | 06:46 AM
William's Avatar
William
I would look for a F100 65-79 with a 6 cylinder engine. I'd grab the flywheel, starter, transmission, crossmember, drive shaft and all the linkage, kick down and radiator. I think you will need to fabricate some type of cable shift system since the transmission is so far away from the driver. This vehicle is unique so hopefully you can find someone that has already done this swap. Ford installed automatics in these trucks so you may find the parts to install the Ford shifter. Good luck and Welcome to FTE!
Scottt Bealss
May 24, 2017 03:27 PM
ryan73ford
Feb 8, 2017 07:15 PM
BossEliminator
19
Jun 1, 2016 05:53 PM
coalnation
Large Truck
Aug 8, 2015 12:37 PM
Prozon
Offroad & 4x4
Aug 12, 2008 10:35 PM
