Sponsored by: Real Truck
Blown fuse
Old Dec 25, 2015 | 03:45 AM
Stuck in germany's Avatar
Stuck in germany
Blown fuse
My truck keeps blowing fuse 28 in the inside fuse box. This fuse belongs to the ignition relay, and only blows when I go to start the truck. It is intermittent
Old Dec 25, 2015 | 06:45 AM
Just Strokin's Avatar
Just Strokin
Might help if you would give some info about your truck....Year, model and engine would help.
Have you done in checks with a meter for anything shorted directly to ground? Checked for care wires in the harness?
Old Dec 25, 2015 | 07:05 AM
Stuck in germany
Sorry it is a 2010 F250 super duty 6.4L 4×4
No meter checks but visual on all the wires I could see nothing stands out.
Thought it was the tow/hual wire as it had some white marks on the outer protective shell but I disconnected it and it still blew the fuse.
Old Dec 25, 2015 | 01:30 PM
projectSHO89's Avatar
projectSHO89
You'd best go back and look that up again in the owner's manual....
Old Dec 25, 2015 | 01:44 PM
Just Strokin
hope this helps you solve the problem...
Old Dec 25, 2015 | 02:55 PM
Stuck in germany
Your right sorry it's ignition switch feed,
Old Dec 25, 2015 | 03:00 PM
Stuck in germany
Here is what the manual says
It's number 27 20a with fuse 28 being the only one that blows
Old Dec 25, 2015 | 03:10 PM
projectSHO89
Yes, it does. You said it was F28 for the ign switch. However, F28 is for the radio, F27 is for the ign system.
So, is it F27 or F28 that is blowing?
Old Dec 25, 2015 | 03:30 PM
Stuck in germany
F27 with fuse 28 blowing on the passenger compartment fuse as read in the description.
Old Dec 25, 2015 | 03:35 PM
projectSHO89
That doesn't make any sense..... WHICH FUSE IS ACTUALLY BLOWING?
Old Dec 25, 2015 | 04:02 PM
Stuck in germany
So its 27 on the left column then you move to the right column and its number 28
Old Dec 25, 2015 | 06:29 PM
projectSHO89
Last chance.
How hard is to look at the diagram in the owner's manual and specifically identify the fuse that blows instead of going back and forth and never managing to supply a clear and concise answer?
Old Dec 26, 2015 | 01:51 AM
Stuck in germany
I am giving a clear answer. If you look at the picture I posted and read the description I am saying it is fuse 28 ignition switch feed.
In the passenger fuse compartment,
Old Dec 26, 2015 | 03:31 AM
Lossoftraction's Avatar
Lossoftraction
Let me ask just what is your problem? Is it that the truck does not run or start or is it that the fuse for the radio keeps blowing? When the title of your post is blown fuse and your name stuck in Germany I think your vehicle will not start. Fuse 28 is fed from fuse 27 but is only supposed to be connected to the radio.
Old Dec 26, 2015 | 04:46 AM
Stuck in germany
It is 27 in the picture I posted and if you read the description to the right of 27 it list the fuaes that go to that system in the ignition switch feed. Only number 28/out of all those fuses in the column keeps blowing. The truck will not start as soon as I turn the key the fuse blows.
So all fuses within the ignition feed switch
28,42,43,44,45 all in the passenger side fuse box. Out of those fuses listed only 28 blows
I will post a picture of the fuse box and the bix covermaybeitwill make it a little clearer.
